STM32F7 bootloader based on ChibiOS
elagil
Has thanked: 8 times
Post by elagil »
Hello!
I am trying to write a bootloader that allows loading of a new image over ethernet. I did not really find anything recent regarding this topic, so I looked for inspiration in older STM32F4 code.
The bootloader shall always be started first and wait for a new image or boot signal over ethernet (alternatively, timeout). This is important for in application programming of many processors at once.
The first step is to write a ChibiOS based bootloader that just jumps to the user application. I found some code snippets and combined them to the following routine. As far as I understood, the steps to take are as follows (please correct me if this is wrong):
- A user application address is given. The start of the user application contains the vector table
- From this vector table, the actual application address (reset interrupt vector?) is extracted
- Disable and clear pending interrupts
- Move stack pointer to user application vector table
- The previously extracted application address is finally called
Here is the code so far, for loading a user program:
void jumpToUser(uint32_t address)
  typedef void (*pFunction)(void);
  pFunction Jump_To_Application;
   * variable that will be loaded with the start address of the application
  __IO uint32_t * JumpAddress;
  const __IO uint32_t * ApplicationAddress = (__IO uint32_t *) address;
   * get jump address from application vector table
  JumpAddress = (__IO uint32_t *) ApplicationAddress[1];
   * load this address into function pointer
  Jump_To_Application = (pFunction) JumpAddress;
  /* Stop system? */
  chSysDisable();
   * Clear pending interrupts
   * Removes the pending state from the PendSV exception.
  SCB_ICSR = ICSR_PENDSVCLR;
  /* Disable all interrupts */
  int i;
  for(i = 0; i < 8; ++i)
    NVIC->ICER[i] = NVIC->IABR[i];
  /* set stack pointer as in application's vector table */
  __set_MSP((uint32_t) (ApplicationAddress[0]));
  Jump_To_Application();
I have some problems with compilation on STM32F7 processors.
This:
does not exist on STM32F7. How can I clear all pending interrupts (or is it even necessary)? I found "__disable_irq()" which disables all interrupts but does not clear pending interrupts. I guess it is similar to what "chSysDisable()" does.
Generally, the user programm shall find conditions just like after a reset. How can I accomplish that?
Thank you in advance,
Adrian
steved
Has thanked: 12 times
Been thanked: 138 times
Re: STM32F7 bootloader based on ChibiOS
Post by steved »
elagil wrote:This:
I just used:
SCB->ICSR = (0x1U << 27);//ICSR_PENDSVCLR;
Either it works, or its harmless!
The earlier code in your post looks OK (you probably found the same sources I did!).
This sort of thing does seem to necessitate reading of bits of Arm's programming manual.
elagil
Post by elagil »
Thank you for the suggestion. By the way, I just found this defined in /os/common/ext/CMSIS/include/core_cm7.h
#define SCB_ICSR_PENDSVCLR_Pos             27U                                            /*!< SCB ICSR: PENDSVCLR Position */
#define SCB_ICSR_PENDSVCLR_Msk             (1UL << SCB_ICSR_PENDSVCLR_Pos)                /*!< SCB ICSR: PENDSVCLR Mask */
I will use this for clearing the interrupts.
elagil
Post by elagil »
So, the bootloader seems to do something but it does not jump to my user application.
I suspect that I do something wrong when building the user application for use with the bootloader. For enabling bootloader compatibility, I changed the linker file, so that flash0 starts at 0x08004000. I let my bootloader jump to that location as well.
Also, I added
#define CORTEX_VTOR_INIT 0x4000
to the chconf.h file of my user application.
Am I missing something? When "Jump_To_Application()" is called, the reset handler jumps back to the start of the bootloader.
I noticed that the application start addresses of both the bootloader and the user program are equal (contents of 0x08000000+4 and 0x08004000+4 are both 0x00200201). Is that expected?
Note that CORTEX_VTOR_INIT is no more required in recent versions, VTOR is initialized by crt0.S.
elagil
Post by elagil »
That is good to know. Then, changing the flash start address in the linker file should be enough.
I am still not sure, if the application entry point in my user application (stored at 0x08004000+4) is correct (I assume not).
elagil
Post by elagil »
I noticed that I seem to be using ITCM flash. So, I changed something else in the linker file of the user application:
    flash1  : org = 0x00204000, len = 1M - 0x4000        /* Flash as ITCM */
This seems to work. I think that the bootloader does jump to the user application now. However, the user application is trapped in this function when I debug it (after the jump):
 * @brief   Returns the system time.
 * @return              The system time.
 * @notapi
static inline systime_t port_timer_get_time(void) {
  return stGetCounter();
Probably, I have to de-initialize all hardware including clock generation. Currently, I am using HSE and PLL for my clock. Can you point me to some resources with regard to completely stopping the system? I found the link to the chibiOS documentation, but it is very generic.
steved
Post by steved »
If bootloader and application clock configurations are the same, there's a #define STM32_NO_INIT which leaves that bit alone. Otherwise you could well be right about the clock setting code making assumptions about register settings.
The clocks are initialised by a call from the board file, so you can always write your own replacement routine.
The HAL initialisation also resets many of the peripherals - could that affect something?
It's not quite clear why your code hangs where it does - on a quick look stGetCounter() is just a register read.
elagil
Post by elagil »
It seems like there was some driver problem after standby of my PC. After a restart, the bootloader jump works fine and the user application runs!
Thanks for the suggestions.
franek.bmw
Post by franek.bmw »
could you share your LD file from applicatoin project?
I have some problems with starting app after jump from bootloader.
Thank you in advance!
Franek
