chprintf enhancement Topic is solved
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
I made a small change to chprintf() to support '+' within the formatting definition.
Also wasn't clear on a quick look whether getting the width specification from a variable would work; I've highlighted this and suggested an alternative.
chprintf.zip
(2.85 KiB) Downloaded 552 times
Re: chprintf enhancement
bump
steved
Post by steved »
Updated for 19.1
chprintf.zip
(2.91 KiB) Downloaded 476 times
I merged it with some fixes and also made some other changes. It is possible I introduced problems but it was needed, final zero was not always detected in the format string if malformed. That TODO was correct IMO, fixed that as well.
FXCoder
Has thanked: 188 times
Been thanked: 134 times
Post by FXCoder »
The .n precision was broken by the malformed format string detection...
Bob
Index: chprintf.c
--- chprintf.c   (revision 12837)
+++ chprintf.c   (working copy)
@@ -203,18 +203,13 @@
         precision = va_arg(ap, int);
       else {
-        while (true) {
+        while (c >= '0' && c <= '9') {
+          c -= '0';
+          precision = precision * 10 + c;
           c = *fmt++;
           if (c == 0) {
             return n;
-          if (c >= '0' && c <= '9') {
-            c -= '0';
-            precision = precision * 10 + c;
-          else {
-            break;
Fix committed thanks.
