Strange behavior of mailboxes
Alexte
Post by Alexte »
simple example, compiles without errors and warnings
chibios 16.1.9
#include "ch.h"
#define MODULE_ID 222
#define CAN_BUFFER_SIZE 32
mailbox_t can_send_mailbox;
msg_t can_send_buffer[CAN_BUFFER_SIZE];
static const CANConfig cancfg = {CAN_MCR_ABOM | CAN_MCR_AWUM | CAN_MCR_TXFP,
                                 CAN_BTR_SJW(1) | CAN_BTR_TS2(1)
                                     | CAN_BTR_TS1(6) | CAN_BTR_BRP(179)};
 * Receiver thread.
static THD_WORKING_AREA(can_rx_wa, 256);
static THD_FUNCTION(can_rx, p) {
  event_listener_t el;
  CANRxFrame rxmsg;
  (void)p;
  chRegSetThreadName("receiver");
  chEvtRegister(&CAND1.rxfull_event, &el, 0);
  while (!chThdShouldTerminateX()) {
    if (chEvtWaitAnyTimeout(ALL_EVENTS, MS2ST(100)) == 0)
      continue;
    while (canReceive(&CAND1, CAN_ANY_MAILBOX, &rxmsg, TIME_IMMEDIATE) == MSG_OK ) {
      palTogglePad(IOPORT3, GPIOC_LED);
  chEvtUnregister(&CAND1.rxfull_event, &el);
 * Transmitter thread.
static THD_WORKING_AREA(can_tx_wa, 256);
static THD_FUNCTION(can_tx, p) {
  CANTxFrame txmsg;
  uint8_t *pbuf; // буфер сообщений
  (void)p;
  chRegSetThreadName("transmitter");
  txmsg.IDE = CAN_IDE_EXT;
  txmsg.EID = 0x01234567;
  txmsg.RTR = CAN_RTR_DATA;
  txmsg.DLC = 8;
  txmsg.data32[0] = 0x55AA55AA;
  txmsg.data32[1] = 0x00FF00FF;
    // вот здесь тред останавливается и ждет пока не появятся в майлбоксе сообщения
    chMBFetch(&can_send_mailbox, (msg_t *)&pbuf, TIME_INFINITE);
    txmsg.EID = (uint32_t)(1 << 24 | 2 << 16 | 0 << 8 | pbuf[0]);
    canTransmit(&CAND1, CAN_ANY_MAILBOX, &txmsg, MS2ST(100));
    chThdSleepMilliseconds(30);  // calculate = 1 / can_speed * 600
int main(void) {
  // create CAN send mailbox
  chMBObjectInit(&can_send_mailbox, can_send_buffer, CAN_BUFFER_SIZE);
  canStart(&CAND1, &cancfg);
  chThdCreateStatic(can_rx_wa, sizeof(can_rx_wa), NORMALPRIO + 7, can_rx, NULL);
  chThdCreateStatic(can_tx_wa, sizeof(can_tx_wa), NORMALPRIO + 7, can_tx, NULL);
  uint8_t buff[1];
  uint8_t i = 0;
  while (true) {
    if(i > 99) i = 0;
    buff[0] = i;
    chMBPost(&can_send_mailbox, (msg_t)buff, TIME_INFINITE);
    i++;
  return 0;
Generate a message on the CAN bus.
The first message passes, the remaining 32 disappear in the mailbox.
The number of missing messages is equal to the size of the mailbox buffer (32)
Can log:
02064.0.0041 | 170.085.170.085.255.000.255.000 17:59:21.945
02064.0.0040 | 170.085.170.085.255.000.255.000 17:59:21.915
02064.0.0039 | 170.085.170.085.255.000.255.000 17:59:21.883
02064.0.0038 | 170.085.170.085.255.000.255.000 17:59:21.853
02064.0.0037 | 170.085.170.085.255.000.255.000 17:59:21.824
02064.0.0036 | 170.085.170.085.255.000.255.000 17:59:21.793
02064.0.0035 | 170.085.170.085.255.000.255.000 17:59:21.765
02064.0.0034 | 170.085.170.085.255.000.255.000 17:59:21.734
02064.0.0033 | 170.085.170.085.255.000.255.000 17:59:21.704
02064.0.0000 | 170.085.170.085.255.000.255.000 17:59:21.677
Re: Strange behavior of mailboxes
I believe the problem is that you are always sending the same value through the mailbox: the same pointer to buf. Try passing directly the message as msg_t, there is no need to pass a pointer.
Alexte
Post by Alexte »
Thanks, I tried your advice, it did not help.
The problem disappears only if you remove the delay of 30 ms after sending CAN messages. Then messages from the mailbox are not lost.
But the delay is needed not to overload the CANbus
Alexte
Post by Alexte »
Everything works on a different board.
Apparently, there was a hardware error.
For a long time I've been using the system and mailboxes, I've never had any problems before.
Giovanni, thanks for the excellent OS!
Alexte
Post by Alexte »
Problem still exists. If we pass a variable to the mailbox, then everything is fine.
Debug terminal
post -> 0
fetch ->   0
post -> 1
post -> 2
post -> 3
fetch ->   1
post -> 4
post -> 5
post -> 6
fetch ->   2
post -> 7
post -> 8
post -> 9
fetch ->   3
post -> 10
post -> 11
post -> 12
fetch ->   4
post -> 13
post -> 14
post -> 15
fetch ->   5
post -> 16
post -> 17
post -> 18
fetch ->   6
post -> 19
post -> 20
post -> 21
fetch ->   7
post -> 22
post -> 23
post -> 24
fetch ->   8
post -> 25
post -> 26
post -> 27
fetch ->   9
If we transfer the array to a mailbox, then messages disappear.
post -> 0
fetch ->   0
post -> 1
post -> 2
post -> 3
fetch ->   3
post -> 4
post -> 5
post -> 6
fetch ->   6
post -> 7
post -> 8
post -> 9
fetch ->   9
post -> 10
post -> 11
post -> 12
fetch ->   12
post -> 13
post -> 14
post -> 15
fetch ->   15
post -> 16
post -> 17
post -> 18
fetch ->   18
post -> 19
post -> 20
post -> 21
fetch ->   21
post -> 22
post -> 23
post -> 24
fetch ->   24
post -> 25
post -> 26
post -> 27
fetch ->   27
post -> 28
post -> 29
post -> 30
fetch ->   30
If in the second example, remove the delay in the thread
chThdSleepMilliseconds (300);
Then everything works correctly
post -> 0
fetch ->   0
post -> 1
fetch ->   1
post -> 2
fetch ->   2
post -> 3
fetch ->   3
post -> 4
fetch ->   4
post -> 5
fetch ->   5
post -> 6
fetch ->   6
post -> 7
fetch ->   7
post -> 8
fetch ->   8
post -> 9
fetch ->   9
post -> 10
fetch ->   10
post -> 11
fetch ->   11
post -> 12
fetch ->   12
post -> 13
fetch ->   13
post -> 14
faisal
Has thanked: 45 times
Been thanked: 62 times
Post by faisal »
Can you try increasing the relative priority of the transmitter or receiver thread?
Relative priority should not matter, I suggest removing all sleeps except where you do chMBPost(), the threads would wait anyway, no need to add sleep.
