one-wire on UART
WaL
one-wire on UART
Post by WaL »
Hello! I'm just starting to program and I do not understand much :oops:
The task was to read the code from DS1990
I tried to do this on UART, but nothing comes out
I can send a reset signal and get a response from DS1990. I did it on USART and on UART, for example:
halconf.h
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE    9600
main:
sdStart(&SD1, NULL);
  uint8_t reset_onewire=0xF0;
  uint8_t readrom[8]={0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF};
  while(1)
    sdWrite(&SD1, reset_onewire,1);
    chThdSleepMilliseconds(500);
I connected the terminal to the UART and watch the result there.
If DS1990 is connected, then I get the answer E0, and if not, then F0
But the next command should be sent at 115200 baud rate. And I do not know how to change the transmission speed quickly, since if you restart the serial driver from a different configuration it takes a long time
Maybe I'll do it completely wrong?
I hope you understand my English, since I used Google Translate :lol:
I use STM32F103C8T6 ( BLUEPILL board)
Re: one-wire on UART
This forum is not for support, you should post in the STM32 section.
Make sure your output pin is assigned to UART, by default pins are GPIO, see your board.h.
WaL
Post by WaL »
Thanks! My code:
#define GPIOA_USART1_TX         9
#define GPIOA_USART1_RX         10
and
#define VAL_GPIOACRH            0x888884B8      /* PA15...PA8 */
But as such, UART transmission works. The question is how to change the baud rate without restarting the driver, since it takes a long time to restart it!
Maybe I do not understand how to implement a 1-wire interface. But if you believe these images, you need to transfer data at different baud rates
Changing speed is done using sdStart() again (without calling sdStop()), note that if you call it again the execution time is much smaller because just the UART is reinitialized.
WaL
Post by WaL »
Yes, it really works, thanks!
But for some reason the sensor still does not answer me!
I send him the following data but I do not get a response
static SerialConfig uartCfg1 =
    9600, // bit rate
  static SerialConfig uartCfg2 =
      115200, // bit rate
  uint8_t readrom_cmd[8]={0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF};
  uint8_t readrom[8]={0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF};
  while(1)
    sdStart(&SD1, &uartCfg1);
    sdWrite(&SD1, &reset_onewire,1);
    sdStart(&SD1, &uartCfg2);
    sdWrite(&SD1, &readrom_cmd,8);
    for (int i=0; i<8;i++)
      sdWrite(&SD1, &readrom,8);
The terminal shows 64 bits of FF.
WaL
Post by WaL »
In fact, it seems that the first byte at 9600 baud does not have time to be transmitted in this case
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
You have to wait until the transmitter shift register is empty before changing the speed.
Use the TxEnd2 callback to signal this point and set a flag, then change the baud rate.
Incidentally, while using a UART for this is perfectly possible, it is common to either 'bit-bang' the interface, or use an interface chip such as the DS2484 to help. (The latter deals with all of the timing and line drive issues)
rew
Been thanked: 14 times
Post by rew »
Guys,
that chip talks a protocol called "onewire". The chibios codes seem to hint that you're trying to use the USART for communicating with this thing. That's not going to work, just like that. I vaguely remember that a trick was possible, by tying the RX and TX lines together, but I don't remember how that was done.
In any case, the chip will transmit a bit after you've asked it to send the next one, So things are not as simple as requesting something and then just waiting for the bits to come in.
I would recommend that you look for a "one wire library", instead of messing with the serial port driver.
rew
Post by rew »
I think I remember now: You wire the RX and the TX of the uart together. Configure the TX pin not as the normal "push-pull" but as opendrain. Now you send an "0xff" at the correct baud rate, and the one-wire device will be able to send you a single bit. It will keep the dataline pulled low for a few bit-periods to send a 0 and it will return the line to high asap for a 1. Now by checking the RX byte, you can figure out how long the device kept the line low. If you get 0x00, obviously that was 8 bit times. and a zero. But it won't keep it low that long so you'll see 0x01, 0x03, ... when you recieve a "0" bit.
faisal
Has thanked: 45 times
Been thanked: 62 times
Post by faisal »
