Crypto driver support Topic is solved
Moderator: tfAteba
tfAteba
Has thanked: 91 times
Been thanked: 50 times
Post by tfAteba »
Hello Giovanni,
I'm trying to add a crypto driver for the XMEGA architecture.
For the moment I just want to test the AES algorithm, so I had the idea to disable all the other algorithm in the driver header file (os/hal/ports/AVR:XMEGA/LLD/CRYPv1/hal_crypto_lld.h)
 30 /*==========================================================================*/
 31 /* Driver constants.                                                        */
 32 /*==========================================================================*/
 33
 34 /**
 35  * @name    Driver capability switches
 36  * @{
 37  */
 38 #define CRY_LLD_SUPPORTS_AES                TRUE
 39 #define CRY_LLD_SUPPORTS_AES_ECB            FALSE
 40 #define CRY_LLD_SUPPORTS_AES_CBC            FALSE
 41 #define CRY_LLD_SUPPORTS_AES_CFB            FALSE
 42 #define CRY_LLD_SUPPORTS_AES_CTR            FALSE
 43 #define CRY_LLD_SUPPORTS_AES_GCM            FALSE
 44 #define CRY_LLD_SUPPORTS_DES                FALSE
 45 #define CRY_LLD_SUPPORTS_DES_ECB            FALSE
 46 #define CRY_LLD_SUPPORTS_DES_CBC            FALSE
 47 #define CRY_LLD_SUPPORTS_SHA1               FALSE
 48 #define CRY_LLD_SUPPORTS_SHA256             FALSE
 49 #define CRY_LLD_SUPPORTS_SHA512             FALSE
 50 #define CRY_LLD_SUPPORTS_HMAC_SHA256        FALSE
 51 #define CRY_LLD_SUPPORTS_HMAC_SHA512        FALSE
 52 #define CRY_LLD_SUPPORTS_TRNG               FALSE
Then I have the following errors:
Compiling hal.c
In file included from ../../../../os/hal/include/hal.h:136:0,
                 from ../../../../os/hal/src/hal.c:25:
../../../../os/hal/include/hal_crypto.h:345:32: error: unknown type name ‘HMACSHA256Context’
                                HMACSHA256Context *hmacsha256ctxp);
../../../../os/hal/include/hal_crypto.h:347:34: error: unknown type name ‘HMACSHA256Context’
                                  HMACSHA256Context *hmacsha256ctxp,
../../../../os/hal/include/hal_crypto.h:351:33: error: unknown type name ‘HMACSHA256Context’
../../../../os/hal/include/hal_crypto.h:354:32: error: unknown type name ‘HMACSHA512Context’
                                HMACSHA512Context *hmacsha512ctxp);
../../../../os/hal/include/hal_crypto.h:356:34: error: unknown type name ‘HMACSHA512Context’
                                  HMACSHA512Context *hmacsha512ctxp,
../../../../os/hal/include/hal_crypto.h:360:33: error: unknown type name ‘HMACSHA512Context’
../../../../os/common/ports/AVR/compilers/GCC/rules.mk:174: recipe for target 'build/obj/hal.o' failed
make: *** [build/obj/hal.o] Error 1
The same errors also appear in STM32 code if I made the same modification to the STM driver.
I think the hal_crypto must have a conditional compilation to avoid that errors if the driver do not support one or many algorithm.
Can I make change to the code? to resolve this?
What do you think about? Another way to do?
Re: Crypto driver support
It is some conditional missing, it is supposed to allow you to disable algorithms. Not very tested because currently there is no implementation, I will implement it for STM32 at some point.
Propose a patch, if it is a totally obvious error then make the change directly.
tfAteba
Post by tfAteba »
I will make change to the code directly and you will improve or modify if necessary.
Thanks
tfAteba
Post by tfAteba »
The correction is done.
I have tested that the STM code is still compiling even if the some algorithm are disable.
Even if those algorithm are not part of the MCU hardware, I think it could be easy to have some macros in halconf.h or another configuration file.
Those macros should then overwrite the macros locate in os/hal/potrs/STM32/LLD/CRYPv1/hal_crypto_lld.h that would then be easy to select in user application the algorithm to use.
I will now insert my crypto driver for the XMEGA family ;)
I had to make more changes, conditionals were required for all algorithms, not just HMAC. In addition, high level functions are not supposed to have conditionals, those are always present.
I hope to not have introduced problems.
tfAteba
Post by tfAteba »
I will test after your modification and see if any problem have been introduce.
Can we change the prototypes of all functions? In order to add "key" as parameters. I know it will break all the existing demo code but it will be easier for me to implement other algorithms.
Sorry no, key cannot be part of the API, there are scenarios where you don't have the key which is stored in a secure vault, you can only use it, not know it.
You nee to use the transient key mechanism if the key is provided by application.
tfAteba
Post by tfAteba »
Thanks for the answer, I was not aware of that, :) happy to learn how thins works.
tfAteba
Post by tfAteba »
I have just update my driver according to your modifications.
I had troubles, regarding the two errors code that I have define for Encryption and Decryption.
So I replace them by the new error code 'CRY_ERR_OP_FAILURE' then my application compile as before :) .
Yes, it is not necessary to have several error codes. Hash operations do not do encrypt/decrypt so something more generic was needed.
