Thread scheduling - unexpected behavior
Raul
Has thanked: 3 times
Post by Raul »
Hi all,
I have a conceptual/super simple test case whose result I'm struggling to fathom.
All the configuration is as set in the STM32F407 Discovery demo, discovery board is the hardware platform. Tested with -O2 and -O0, no difference.
I wanted to verify that among all the threads ready for execution, the one with the highest priority is the one being executed,
no exceptions to this rule.
It seems to be the case, what I find striking is the behavior of the blinker thread, I would expect it to alternate output state at 10 Hz.
 22 /*
 23  * This is a periodic thread that does absolutely nothing except flashing
 24  * a LED.
 25  */
 26 static THD_WORKING_AREA(waThread1, 128);
 27 static THD_FUNCTION(Thread1, arg) {
 28
 29   (void)arg;
 30   chRegSetThreadName("blinker");
 31   while (true) {
 32     chThdSleepMilliseconds(100);
 33     palTogglePad(GPIOD, GPIOD_LED3);     /* Orange.  */
 34   }
 35 }
 36
 37 /*
 38  * Application entry point.
 39  */
 40 int main(void) {
 41
 42   /*
 43    * System initializations.
 44    * - HAL initialization, this also initializes the configured device drivers
 45    *   and performs the board-specific initializations.
 46    * - Kernel initialization, the main() function becomes a thread and the
 47    *   RTOS is active.
 48    */
 49   halInit();
 50   chSysInit();
 51
 52   /*
 53    * Creates the example thread.
 54    */
 55   chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
 56
 57   /*
 58    * Normal main() thread activity, in this demo it does toggle
 59    * a yellow led as fast as possible while in running state.
 60    */
 61   while (true)
 62   {
 63         palTogglePad (GPIOD, GPIOD_LED4);       /* Yellow.  */
 64   }
 65 }
Output registered with logic analyzer (colours of the channels map to the leds):
Any ideas?
Raul
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Re: Thread scheduling - unexpected behavior
Post by wurstnase »
The concept of chibios is a chThdSleep in the main loop.
Raul
Post by Raul »
Hi Wurstnase,
That was quick :) Could you elaborate on that please? Is that specific to the main thread? Would the result be any different if I moved the main thread to a separate one, lower priority than blinker and main to sleep infinitely?
From a theoretic perspective, any reason not to have a low priority thread that doesn't sleep?
Raul
Main() is a thread at priority NORMALPRIO, if it does not release the CPU then all threads at lower priority will never be scheduled, other threads at NORMALPRIO would be scheduled only if main() calls chThdYield() or its time slice elapsed (depending on if RR scheduling is cooperative or preemptive).
Note that in the test suite there are test cases testing exactly the behaviour you tested, you may look at those too.
Raul
Post by Raul »
That makes sense, that was my understanding (for a cooperative kernel like the one in the example). Note that in the example I posted, the blinker thread has a priority of NORMALPRIO+1.
I expanded the example slightly, added a push button to toggle the yellow led in the main.
I thought I had a decent understanding of the scheduler, I would have thought that the orange led would be toggling regularly every 100 ms. Are the results that I am measuring what you would expect?
 22 /*
 24  * a LED.
 25  */
 28
 29   (void)arg;
 31   while (true) {
 34   }
 35 }
 36
 37 /*
 39  */
 40 int main(void) {
 41
 42   /*
 48    */
 49   halInit();
 50   chSysInit();
 51
 52   /*
 54    */
 56
 57   /*
 60    */
 61   while (true)
 62   {
 63           if (! palReadPad (GPIOA, GPIOA_BUTTON))
 64                 palTogglePad (GPIOD, GPIOD_LED4);       /* Yellow.  */
 65   }
 66 }
Button open
Button open
Button closed
Button closed
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
I have reproduced your behavior.
This has nothing to do with the scheduler which work as expected, the problem is on the GPIO side. When you do a toogle, one have to read / modify / write the register, and theses 3 operations are not atomic. So doing this at high frequency without locking on the same port from two threads is the problem.
The problem is solved if :
a/ one keep toogle API but use two pins on two different ports (no shared resource)
or
b/ one replace tooglePad by a setPad followed by clearPad ( theses operations are atomic)
or
c/ one use bitband alias region on MCU that have this capability
Alexandre
Raul
Post by Raul »
Hi Alexandre,
Thanks for taking the time of actually run it and shedding some light, that makes perfect sense (so great to know the cause !). Didn't realiaze about the atomicity of the toggle call.
Also never heard of bit-banding before, appreciated.
Raul
wurstnase
Post by wurstnase »
What could be a reason to use a bit-banding instead of the set/reset registers on STM32 (BSRR/BRR)?
alex31
Post by alex31 »
I don't advocate bitbanding for all the situations. In a set/reset scenario, BSRR/BRR are the way to go (chibios hal use it), it's simpler and faster than using bitbanding. But in the special case of toggling one bit, the hardware take care of atomicity at register level.
alex31
Post by alex31 »
here a small header only library helper for bitbanding :
bitband.h on github
Alexandre
