Speed profiling using hal_serial_usb Topic is solved
sabdulqadir
Has thanked: 13 times
Been thanked: 4 times
Post by sabdulqadir »
Hi All,
I have been testing the speed on hal_serial_usb, testing with different size for [font=Courier New]SERIAL_USB_BUFFERS_SIZE[/font], [font=Courier New]SERIAL_USB_BUFFERS_NUMBER[/font] and the size of buffer which goes in [font=Courier New]chnWrite(&SDU2, (const uint8_t *)&test_buff, TEST_BUFFER_SIZE)[/font].
I realized what matters most is [font=Courier New]SERIAL_USB_BUFFERS_SIZE[/font]. I was able to squeeze 19MB/s from running the driver alone on STM32F723.
But there was one more parameter which changed the speed substantially to 29MB/s. That was increasing the size check in [font=Courier New]obqWriteTimeout() [hal_buffers.c][/font]
    /* Smaller chunks in order to not make the critical zone too long,
       this impacts throughput however.*/
    if (size > 64U) {
      /* Giving the compiler a chance to optimize for a fixed size move.*/
      memcpy(obqp->ptr, bp, 64U);
      bp        += 64U;
      obqp->ptr += 64U;
      w         += 64U;
Do you guys think this parameter should be exposed so that it can be fine-tuned?
Thanks,
AQ
Re: Speed profiling using hal_serial_usb
Thanks for testing, probably yes, it should be exposed, moving this topic in "change request".
A new setting has been added: BUFFERS_CHUNKS_SIZE. It applies to both obqWriteTimeout() and ibqReadTimeout(). The default is still 64.
sabdulqadir
Thanks Giovanni,
I do have a concern though. Should this change be pulled out to the configuration files? That way, the application would be able to fine tune this parameter.
Thanks,
AQ
You can put that definition in halconf.h, uncommon settings are not usually present in configuration files in order to keep those not too complex. You may recommend different defaults after your testing.
