STM32 code unstable on repository for a while
I am implementing changes to the STM32 support in order to address differences among sub-families, the STM32 code will be "unstable" on the repository for a while.
Re: STM32 code unstable on repository for a while
Thank you very much for the information!
Keep going your good work, sir :)
Changes are done, repo should be "stable" again, please let me know in if there are problems.
mabl
Post by mabl »
I get an error compiling the STM32F107 demo:
mabl@mikrocanonix [05:32:53] [/tmp/ChibiOS/demos/ARMCM3-STM32F107] [master]
-> % make
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m3 -O2 -ggdb -fomit-frame-pointer -falign-functions=16 -ffunction-sections -fdata-sections -fno-common -Wall -Wextra -Wstrict-prototypes -Wa,-alms=build/lst/ -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTERWORKING -MD -MP -MF .dep/build.d -I. -I../../os/ports/common/ARMCMx/CMSIS/include -I../../os/ports/common/ARMCMx -I../../os/ports/GCC/ARMCMx -I../../os/ports/GCC/ARMCMx/STM32F1xx -I../../os/kernel/include -I../../test -I../../os/hal/include -I../../os/hal/platforms/STM32F1xx -I../../os/hal/platforms/STM32 -I../../os/hal/platforms/STM32/GPIOv1 -I../../os/hal/platforms/STM32/I2Cv1 -I../../os/hal/platforms/STM32/RTCv1 -I../../os/hal/platforms/STM32/USARTv1 -I../../os/hal/platforms/STM32/USBv1 -I../../boards/OLIMEX_STM32_P107 -I../../os/various main.c -o main.o
mkdir -p build/obj
mkdir -p build/lst
Compiling ../../os/ports/GCC/ARMCMx/crt0.c
Compiling ../../os/ports/GCC/ARMCMx/STM32F1xx/vectors.c
Compiling ../../os/ports/GCC/ARMCMx/chcore.c
Compiling ../../os/ports/GCC/ARMCMx/chcore_v7m.c
Compiling ../../os/ports/common/ARMCMx/nvic.c
Compiling ../../os/kernel/src/chsys.c
Compiling ../../os/kernel/src/chdebug.c
Compiling ../../os/kernel/src/chlists.c
Compiling ../../os/kernel/src/chvt.c
Compiling ../../os/kernel/src/chschd.c
Compiling ../../os/kernel/src/chthreads.c
Compiling ../../os/kernel/src/chdynamic.c
Compiling ../../os/kernel/src/chregistry.c
Compiling ../../os/kernel/src/chsem.c
Compiling ../../os/kernel/src/chmtx.c
Compiling ../../os/kernel/src/chcond.c
Compiling ../../os/kernel/src/chevents.c
Compiling ../../os/kernel/src/chmsg.c
Compiling ../../os/kernel/src/chmboxes.c
Compiling ../../os/kernel/src/chqueues.c
Compiling ../../os/kernel/src/chmemcore.c
Compiling ../../os/kernel/src/chheap.c
Compiling ../../os/kernel/src/chmempools.c
Compiling ../../test/test.c
Compiling ../../test/testthd.c
Compiling ../../test/testsem.c
Compiling ../../test/testmtx.c
Compiling ../../test/testmsg.c
Compiling ../../test/testmbox.c
Compiling ../../test/testevt.c
Compiling ../../test/testheap.c
Compiling ../../test/testpools.c
Compiling ../../test/testdyn.c
Compiling ../../test/testqueues.c
Compiling ../../test/testbmk.c
Compiling ../../os/hal/src/hal.c
Compiling ../../os/hal/src/adc.c
Compiling ../../os/hal/src/can.c
Compiling ../../os/hal/src/ext.c
Compiling ../../os/hal/src/gpt.c
Compiling ../../os/hal/src/i2c.c
Compiling ../../os/hal/src/icu.c
Compiling ../../os/hal/src/mac.c
Compiling ../../os/hal/src/mmc_spi.c
Compiling ../../os/hal/src/mmcsd.c
Compiling ../../os/hal/src/pal.c
Compiling ../../os/hal/src/pwm.c
Compiling ../../os/hal/src/rtc.c
Compiling ../../os/hal/src/sdc.c
Compiling ../../os/hal/src/serial.c
Compiling ../../os/hal/src/serial_usb.c
Compiling ../../os/hal/src/spi.c
Compiling ../../os/hal/src/tm.c
Compiling ../../os/hal/src/uart.c
Compiling ../../os/hal/src/usb.c
Compiling ../../os/hal/platforms/STM32F1xx/stm32_dma.c
Compiling ../../os/hal/platforms/STM32F1xx/hal_lld.c
Compiling ../../os/hal/platforms/STM32F1xx/adc_lld.c
Compiling ../../os/hal/platforms/STM32F1xx/ext_lld_isr.c
Compiling ../../os/hal/platforms/STM32/can_lld.c
Compiling ../../os/hal/platforms/STM32/ext_lld.c
Compiling ../../os/hal/platforms/STM32/gpt_lld.c
Compiling ../../os/hal/platforms/STM32/icu_lld.c
Compiling ../../os/hal/platforms/STM32/mac_lld.c
Compiling ../../os/hal/platforms/STM32/pwm_lld.c
Compiling ../../os/hal/platforms/STM32/serial_lld.c
Compiling ../../os/hal/platforms/STM32/sdc_lld.c
Compiling ../../os/hal/platforms/STM32/spi_lld.c
make: *** No rule to make target `build/obj/.c pal_lld.c', needed by `build/obj/ build/obj/pal_lld.o'.  Stop.
I found a problem in platform.mk, please update and try again.
mabl
Post by mabl »
Great, it works now! :-) Fast as always, Giovanni.
indigos
Post by indigos »
chnPut and chnGet are disappeared from io_channel with commit 35acf78f-673a-0410-8e92-d51de3d6d3f4, is normal?
Yes, moved into the parent interface with names chSequentialStreamPut() and chSequentialStreamGet().
Just got the trunk from the svn repo. Get this erros:
make: *** No rule to make target `/home/tectu/projects/resources/chibios/os/hal/platforms/STM32/i2c_lld.c', needed by `build/obj/i2c_lld.o'.  Stop.
Badger
Post by Badger »
make clean and that will probably go away
