ChibiOS 18.2 STM32H743-SerialDriver Topic is solved
dwawerek
Post by dwawerek »
I changed the RT-STM32H743I-NUCLEO144 example project for STM32H7 in order to use more then one SerialPort, I decided to use UART7(SD7) and UART4(SD4). I made enabled them in halconf.h maped pin contected to UARTs
 //UART4
  palSetPadMode(GPIOD, GPIOD_ZIO_D67, PAL_MODE_ALTERNATE(8));
  palSetPadMode(GPIOD, GPIOD_ZIO_D66, PAL_MODE_ALTERNATE(8));
  sdStart(&SD4, NULL);
  //UART7
  palSetPadMode(GPIOF, GPIOF_PIN6, PAL_MODE_ALTERNATE(7));
  palSetPadMode(GPIOF, GPIOF_ZIO_D62, PAL_MODE_ALTERNATE(7));
  sdStart(&SD7, NULL);
and send Strings through using sdWrite() function
static THD_FUNCTION(Thread3, arg) {
  (void)arg;
  chRegSetThreadName("UART4andUART7");
  while (true) {
    sdWrite(&SD7, "UART7\n", 10);
    chThdSleepMilliseconds(80);
    sdWrite(&SD4, "UART4\n", 10);
    chThdSleepMilliseconds(70);
I got strange output, becuase the Strings from one serialDriver shows paritly in second one output, givie for example: "UAUART7" in console. I know that the sizes of strings and declared in sdWrite are not the same, but shouldn't they work indepently or the data buffor is conected?
Morover after first launch there was an error in hal_serial_lld.h saying that STM32_UART4CLK and STM32_UART7CLK was undeclared but in hal_lld.h there was a similiar declarations STM32_USART4CLK STM32_USART7CLK and after chaning it the errors disapper, so I belivie is just a spelling mistake.
Regards
Damian
alex31
Has thanked: 57 times
Been thanked: 88 times
Re: ChibiOS 18.2 STM32H743-SerialDriver
Post by alex31 »
There is error in your code, namely "out of bound buffer" error.
You have a constant string buffer of lenght 7 including null at the end of string, but you write 10 bytes
The length of your string is 6 including newline, you should use 6 instead of 10.
You can avoid this kind of error using sizeof :
const char uart4Label[] = "UART4\n";
sdWrite(&SD4, uart4Label, sizeof(uart4Label)-1); // -1 because you don't want so send NULL terminator
