ch debugger plugin - stack info
pito
Post by pito »
Hi, is there a short explanation how is the relationship between these stack parameters in the chibios/rt plugin's "Threads" window, pls ?
stack debug.jpg (15.19 KiB) Viewed 2711 times
Re: ch debugger plugin - stack info
Address is the base address of the Working Area where the Thread structure is located.
Stack is the current position of the stack pointer.
StkLimit is the stack limit.
StkUnused is an estimation of the unused stack area.
pito
Post by pito »
So roughly
StkUnused ~ Stack - StkLimit
With main it gives a bigger StkUnused, though. Therefore I asked..
Thanks, p.
PS: the time values are in ms I guess.
No, it is not so simple.
The unused stack is the area starting from StkLimit whose filler value has not been altered, regardless of the current stack position.
