I am trying to get SDMMC working on this board. I started with the main.c code from the STM32F4-SDC project, and modified it for the nucleo board (changed the serial interface, changed the LED pins etc.)
In order to get SDMMC working, I set HAL_USE_SDC to TRUE in halconf.h,
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC TRUE
#endifand set STM32_SDC_USE_SDMMC1 to TRUE in mcuconf.h.
#define STM32_SDC_USE_SDMMC1 TRUEThen in main.c before sdcStart() I manually configure the SDMMC pins for alternate mode 12:
* Manual pin setup for SDMMC since board.h isn't updated yet
palSetPadMode(GPIOC, GPIOC_SDMMC_D0, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
palSetPadMode(GPIOC, GPIOC_SDMMC_D1, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
palSetPadMode(GPIOC, GPIOC_SDMMC_D2, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
palSetPadMode(GPIOC, GPIOC_SDMMC_D3, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
palSetPadMode(GPIOC, GPIOC_SDMMC_CK, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
palSetPadMode(GPIOD, GPIOD_SDMMC_CMD, PAL_STM32_ALTERNATE(12) | PAL_STM32_OSPEED_HIGHEST );
* Initializes the SDIO drivers.
sdcStart(&SDCD1, &sdccfg);When I run the sdc test, it times out trying to connect to the SD card. I don't see any SDMMC pin activity on the oscilloscope either. I am clearly missing something obvious. Is there any demo code for using SDMMC on the F7?
Thanks in advance for any suggestions.
-Matt
