chTimeIsInRangeX always false? Topic is solved
wurstnase
Has thanked: 43 times
Been thanked: 30 times
Post by wurstnase »
I've some issues with the following code:
 * @brief   Checks if the specified time is within the specified time range.
 * @note    When start==end then the function returns always true because the
 *          whole time range is specified.
 * @param[in] time      the time to be verified
 * @param[in] start     the start of the time window (inclusive)
 * @param[in] end       the end of the time window (non inclusive)
 * @retval true         current time within the specified time window.
 * @retval false        current time not within the specified time window.
 * @xclass
static inline bool chTimeIsInRangeX(systime_t time,
                                    systime_t start,
                                    systime_t end) {
  return (bool)((systime_t)((systime_t)time - (systime_t)start) <
                (systime_t)((systime_t)end - (systime_t)start));
When end==start this returns always false, but in the comment it say always true.
When end==start this is always 0. time-start is always > 0, because it's unsigned. In that case 1 < 0 is always false?
In my current specific case:
chTimeIsInRangeX(9682, 9659, 9659)
Re: chTimeIsInRangeX always false?
Moving in bug reports. I think the documentation is wrong in this case. This code changed a while ago but the documentation note persisted.
Making it as documented would probably require one extra check, it is better to keep this code efficient.
wurstnase
Post by wurstnase »
If I'm correct I could now use in the fallback i2c driver?
  i2cp->start = osalOsGetSystemTimeX();
  i2cp->end = i2cp->start + timeout;
  /* or i2cp->end = osalTimeAddX(i2cp->start, timeout); */
instead of this "wrong" code?
  i2cp->end = i2cp->start;
  if (timeout != TIME_INFINITE) {
    i2cp->end += timeout;
I need to review it, for sure it is not very correct to sum systime_t with sysinterval_t directly.
wurstnase
Post by wurstnase »
Please check also my current patch. (Still testing)
diff --git a/os/hal/lib/fallback/I2C/hal_i2c_lld.c b/os/hal/lib/fallback/I2C/hal_i2c_lld.c
index 1482d52f5..209506365 100644
--- a/os/hal/lib/fallback/I2C/hal_i2c_lld.c
+++ b/os/hal/lib/fallback/I2C/hal_i2c_lld.c
@@ -94,7 +94,7 @@ static inline msg_t i2c_check_arbitration(I2CDriver *i2cp) {
 static inline msg_t i2c_check_timeout(I2CDriver *i2cp) {
-  if (!osalOsIsTimeWithinX(osalOsGetSystemTimeX(), i2cp->start, i2cp->end)) {
+  if (!osalTimeIsInRangeX(osalOsGetSystemTimeX(), i2cp->start, i2cp->end)) {
     i2c_write_stop(i2cp);
     return MSG_TIMEOUT;
@@ -105,7 +105,7 @@ static inline msg_t i2c_check_timeout(I2CDriver *i2cp) {
 static msg_t i2c_wait_clock(I2CDriver *i2cp) {
   while (palReadLine(i2cp->config->scl) == PAL_LOW) {
       return MSG_TIMEOUT;
     i2c_delay(i2cp);
@@ -347,14 +347,11 @@ void i2c_lld_stop(I2CDriver *i2cp) {
 msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
                                      uint8_t *rxbuf, size_t rxbytes,
-                                     systime_t timeout) {
+                                     sysinterval_t timeout) {
   /* Setting timeout fields.*/
-  i2cp->end = i2cp->start;
-  if (timeout != TIME_INFINITE) {
-    i2cp->end += timeout;
+  i2cp->end = osalTimeAddX(i2cp->start, timeout);
   CHECK_ERROR(i2c_write_start(i2cp));
@@ -399,14 +396,11 @@ msg_t i2c_lld_master_receive_timeout(I2CDriver *i2cp, i2caddr_t addr,
 msg_t i2c_lld_master_transmit_timeout(I2CDriver *i2cp, i2caddr_t addr,
                                       const uint8_t *txbuf, size_t txbytes,
   /* send start condition */
diff --git a/os/hal/lib/fallback/I2C/hal_i2c_lld.h b/os/hal/lib/fallback/I2C/hal_i2c_lld.h
index 21a7faabf..04614ece7 100644
--- a/os/hal/lib/fallback/I2C/hal_i2c_lld.h
+++ b/os/hal/lib/fallback/I2C/hal_i2c_lld.h
@@ -129,7 +129,7 @@ typedef struct {
    * @brief   Delay of an half bit time in system ticks.
-  systime_t                 ticks;
+  sysinterval_t             ticks;
 #else
    * @brief   Pointer to an externally defined delay function.
@@ -217,10 +217,10 @@ extern "C" {
-                                        systime_t timeout);
+                                        sysinterval_t timeout);
 #ifdef __cplusplus
The default delay needs some rework, because it will trigger now a SV#4. The thdSleep is in a locked section.
Thanks, I must have missed the fallback driver after changing the time API.
Fixed as bugs #1060 and bug #1061 (trunk only right now).
The problem was present in both RT and NIL, also the OS-less OSAL contained a similar problem. Added specific tests to both test suites.
Do you mind giving a try to the modified I2C driver?
wurstnase
Post by wurstnase »
the driver is working now. Only the default delay is still running into a SV#4.
The i2cMasterTransmit call an osalSysLock.
Then it will start the transmit with i2c_lld_master_transmit_timeout.
E.g. in the i2c_write_start you will have:
  palClearLine(i2cp->config->sda);
  i2c_delay(i2cp);
  palClearLine(i2cp->config->scl);
where the default i2c_delay is:
static inline void i2c_delay(I2CDriver *i2cp) {
#if SW_I2C_USE_OSAL_DELAY || defined(__DOXYGEN__)
  osalThreadSleep(i2cp->config->ticks);
#else
  i2cp->config->delay();
Modifying the code to:
  osalSysUnlock();
  osalSysLock();
#else
Could fix it.
I applied a slightly different fix but your solution was correct.
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
Giovanni wrote:Fixed as bugs #1060 and bug #1061 (trunk only right now).
Theses fixes have the side effect to make chThdSleepUntilWindowed(prev, next) to stuck if prev == next.
Alexandre
