Support for STM32F730 Value line MCUs Topic is solved
tecnologic
Has thanked: 21 times
Been thanked: 5 times
Post by tecnologic »
Hi All,
i'm currently porting chibios to STM32F730x8 series. I needed to update the stm header files and created a linker script but when i boot the code i'm immediately struck at _port_switch. which is kind of strange because the call stack says its coming from the first line in the Reset_Handler: b _crt0_entry. I susspect there is some general error either in the code or the linkage.
i attached my changes as a patch but for reference the original code is here: UNIMOC Code
patch1.zip
(2.28 MiB) Downloaded 494 times
tecnologic
Re: Support for STM32F730 Value line MCUs
Its always this vector: VectorF8() at vectors.S:1,021 0x200332
strange thing. if i run the f722 demo i dont have the issue. Ideas?
Is the device really flashed?
tecnologic
yes i'm quite sure it is flashed. When i build the F722ZI Demo i just copy the elf file to the spot of my projects elf file and start the debugger with the same settings. I had a look at stm32_regitsty.h and everything seems to work as expected. I get the j-link download progressbars every time i switch elf files. And verify flash is on as well.
I know i missed some thing in the port but i have no idea whats the problem. The linker script is fine because i changed the demo to use that. I even change the board.h of the demo to define STM32F730xx instead of STM32F722xx. But i cant break the demo. So there must be something wrong with my code and not the port?
tecnologic
Update:
It was my code. The port is WORKING!. If u need any thing more than the patch please ask.
Alex
tecnologic
I found the issue with my code. If i use the cpp wrappers and define a thread that overrides the pure virtual main function of the BaseStaticThread class. I have the issue. This look to me more like a compiler problem or does any one have a idea whats happening?
The code is as simple as that:
#include "ch.hpp"
using namespace chibios_rt;
/* Reference to the server thread.*/
static ThreadReference sref;
 * LED blink sequences.
 * NOTE: Sequences must always be terminated by a GOTO instruction.
 * NOTE: The sequencer language could be easily improved but this is outside
 *       the scope of this demo.
#define SLEEP           0
#define GOTO            1
#define STOP            2
#define BITCLEAR        3
#define BITSET          4
#define MESSAGE         5
typedef struct {
   uint8_t       action;
   union {
      msg_t       msg;
      uint32_t    value;
      ioline_t    line;
} seqop_t;
// Flashing sequence for LED3.
static const seqop_t LED3_sequence[] =
      {BITSET,      LINE_LED_RUN},
      {SLEEP,       800},
      {BITCLEAR,    LINE_LED_RUN},
      {SLEEP,       200},
      {GOTO,        0}
// Flashing sequence for LED4.
static const seqop_t LED4_sequence[] =
      {BITSET,      LINE_LED_MODE},
      {SLEEP,       600},
      {BITCLEAR,    LINE_LED_MODE},
      {SLEEP,       400},
      {GOTO,        0}
// Flashing sequence for LED5.
static const seqop_t LED5_sequence[] =
      {BITSET,      LINE_LED_ERROR},
      {SLEEP,       400},
      {BITCLEAR,    LINE_LED_ERROR},
      {SLEEP,       600},
      {GOTO,        0}
// Flashing sequence for LED6.
static const seqop_t LED6_sequence[] =
      {BITSET,      LINE_LED_PWM},
      {SLEEP,       200},
      {BITCLEAR,    LINE_LED_PWM},
      {SLEEP,       800},
      {GOTO,        0}
 * Sequencer thread class. It can drive LEDs or other output pins.
 * Any sequencer is just an instance of this class, all the details are
 * totally encapsulated and hidden to the application level.
class SequencerThread : public BaseStaticThread<128>
private:
   const seqop_t *base, *curr;                   // Thread local variables.
protected:
   void main(void) override {
      setName("sequencer");
      while (true) {
         switch(curr->action) {
         case SLEEP:
            sleep(TIME_MS2I(curr->value));
            break;
         case GOTO:
            curr = &base[curr->value];
            continue;
         case STOP:
            return;
         case BITCLEAR:
            palClearLine(curr->line);
            break;
         case BITSET:
            palSetLine(curr->line);
            break;
         curr++;
public:
   SequencerThread(const seqop_t *sequence) : BaseStaticThread<128>() {
      base = curr = sequence;
/* Static threads instances.*/
static SequencerThread blinker1(LED3_sequence);
static SequencerThread blinker2(LED4_sequence);
static SequencerThread blinker3(LED5_sequence);
static SequencerThread blinker4(LED6_sequence);
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
  System::init();
   * sleeping in a loop and check the button state.
  while (true) {
    BaseThread::sleep(TIME_MS2I(500));
Thanks
A 27MB patch?
tecnologic
my bad, i updated all the STM32 headers these make the patch so huge. I seperated the changes, so please find attached the real changes to the os code without the ST headers in os/common/ext/st.
Alex
patch_f730_without_st_headers.7z
(2.22 KiB) Downloaded 470 times
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
tecnologic wrote:I found the issue with my code. If i use the cpp wrappers and define a thread that overrides the pure virtual main function of the BaseStaticThread class. I have the issue. This look to me more like a compiler problem or does any one have a idea whats happening?
Thanks
perhaps a static C++ object initialisation problem ?
do you link with g++ ?
Alexandre
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
There was a bug in the scatter files which caused problems linking static classes (IIRC); might be a similar problem here. It's fixed in trunk, but not in the standard 19.1.3 distribution.
Check os\common\startup\ARMCMx\compilers\GCC\ld\rules_Code.ld - line 38 or thereabouts should say:
    .text : ALIGN_WITH_INPUT
