LD Fill holes in memory with FF
honken
Post by honken »
Is it possible to fill any memory holes in LD script for the STM32 build?
Like to make sure that unused memory inside used memory range is set to FF so CRC calc can be done correctly.
regards,
Re: LD Fill holes in memory with FF
You should look into the linker options for that.
https://access.redhat.com/documentation ... tions.html
