SMT32F730 I2C write with strange error
tecnologic
Has thanked: 21 times
Been thanked: 5 times
Post by tecnologic »
Hi all,
here is my test case i want to write 16bytes with the values from 0x50 to 0x5F in the first 16byte page of a AT34C04 EEPROM conected to the I2C Bus.
// write buffer out to ram so that dma can access it.
cacheBufferFlush(write_buffer, sizeof(write_buffer));
status |= i2cMasterTransmitTimeout(I2CP, RW_ADDRESS,
         write_buffer, write_length + 1, nullptr, 0, WRITE_TIMEOUT);
writebuffer is 17bytes long with a 0 for the EEPROMs internal Address in byte 0 of the buffer an then followed by 0x50 - 0x5F.
An here is the problem:
the Address and the first byte are correct but then there is a additional 0????
This is the writebuffer how it is given to the i2cMasterTransmitTimeout function.
From the code of the i2cMasterTransmitTimeout function i can not see where the first 0 comes from. it just gives the buffer pointer to the dma. And i flushed the cache right before the call so data has to be in ram.
Anyone has an idea?
Thanks
Tec
Re: SMT32F730 I2C write with strange error
Everything looks shifted by one position, very strange.
Is your device address a 7 bits one? if not then it could add another byte for the extended address.
tecnologic
I just found the problem. 34xx EEPROM for SPDs of modern RAM DIMMs have 2 256byte halfs to set the half u want to access u need to send an "Set Page Address" command. Which is basically an I2C write with address and according to the data sheet TWO dummy bytes. An i send this command right before the write. Thing was now the EEPROM sends a NACK on the first dummy byte so I2C HW stops transmission and the second dummy byte is some where in the i2C buffer. And this was 0 in my case. When i set it to 0xA5 it sends address 0xA5 0x00 0x50 .....
So my fault. Nasty EEPROMs
Thanks anyway.
