board files, tools/ftl reorganized ?
geoffrey.brown
- Has thanked: 3 times
- Been thanked: 18 times
I was trying to create a board directory for the STM32L475 iot discovery board by starting with the ChibiOS/os/hal/boards/ST_STM32L476_DISCOVERY/ directory, but found that the links in cfg/board.fmpp no longer correspond to the organization of the ChibiOS/tools/ftl directories. I couldn't find and example to copy and don't fully understand what changed.
Re: board files, tools/ftl reorganized ?
I don't understand, could you post the wrong part? the links in the fmpp files look correct to me.
geoffrey.brown
In
ChibiOS/ChibiOS/blob/master/os/hal/boards/ST_STM32L476_DISCOVERY/cfg/board.fmpp
sourceRoot: ../../../../../tools/ftl/processors/boards/stm32l4xx/templates
Structure for ChibiOS/tools/ftl/processors:
/-- conf
-- unitest/test
/-- conf
-- unitest/test
It points to templates into the ChibiOS tree, what is the error?
Inside there are the .ftl template files.
geoffrey.brown
I see where it points, but this directory structure is missing:
perhaps it's a problem with the github mirror of the repo
geoffrey.brown
That makes sense (as a root cause). I didn't see how to submit an issue on the github site for the maintainers of the mirror.
Geoffrey
Geoffrey
electronic_eel
- Has thanked: 8 times
- Been thanked: 23 times
I had the exact same issue before, see http://www.chibios.com/forum/viewtopic.php?f=38&t=4589#p33624 for a detailed analysis of the problem and a suggestion how to fix it.
