Strings to mailboxes
JSStabl
Has thanked: 3 times
Been thanked: 2 times
Post by JSStabl »
I want to send string messages over the mailbox q to serve a thread that then writes out the data over the serial bus. From the ChibiOS book I took an example for a console and created the following threads:
char start_string[] = "start";
char stop_string[] = "stop";
static mailbox_t serial_mb;
static msg_t serial_mb_buffer[10];
uint8_t buffer[8];
THD_WORKING_AREA(serial_output_thread_wa, 128);
THD_FUNCTION(serial_output_thread, arg) {
    (void)arg;
    chRegSetThreadName("Uart Comm Thread");
    chMBObjectInit(&serial_mb, serial_mb_buffer, 10);
    msg_t msg = 0;
    BaseSequentialStream *stream = (BaseSequentialStream *)&SD3;
    while (true) {
        chMBFetchTimeout(&serial_mb, &msg, TIME_INFINITE);
        const char *s_msg = (const char *)msg;
        chprintf(stream, "%s", s_msg);
THD_WORKING_AREA(serial_input_thread_wa, 128);
THD_FUNCTION(serial_input_thread, p) {
    (void) p;
    chRegSetThreadName("Serial Input Thread");
    while (true) {
        //clear buffer
        memset(buffer, 0, sizeof(buffer));
        sdReadTimeout(&SD3, buffer, 5, TIME_MS2I(50));
        if (strcmp((char *) buffer, start_string) == 0) {
            chMBPostTimeout(&serial_mb, (msg_t)"Very long string", TIME_INFINITE);
        } else if (strcmp((char *) buffer, stop_string) == 0) {
            sdWrite(&SD3, buffer, 5);
When typing start I get "very long string" from the serial, so that seems to work. My question now is why and how does that work? The msg_t is an int32 if I recall correctly, that can fit 4 char variables. So why can I enocde a string longer than that? How would I need to cast the buffer variable in order to send it over the q?
Re: Strings to mailboxes
It is very simple, you are not sending a string, you are sending a -pointer- to the string, the string is in its buffer and the buffer must non change until the message is received.
JSStabl
Post by JSStabl »
Ah yes, thats actually perfectly reasonable. Thanks as always!
So I need an extra message buffer that only gets cleared when the message is received. When sending the strings as "directly" encoded the compiler probably treats that as a const string and that doesn't change. So If I want to send a dynamic string from a buffer I need to make sure that buffer is constant before it gets read.
You should look at the "object FIFOs" mechanism in OSLIB, that provides also buffers handling.
JSStabl
Post by JSStabl »
At the risk of going slightly off-topic: I'm trying to implement printf in chibiOS since I have some external libraries that use printf for error messages. I included the syscalls.c and added the STDOUT_SD and it seems to work when being called from the main startup code. However as soon as I run printf from the thread context it stops working. Any ideas why?
ChibiOS has its own chprintf().
Probably the library is trying to do memory allocation internally, this may fail depending on your setup/version/compiler/etc. I haven't tried that extensively, compilers and libraries change very often.
You should also check if you thread has sufficient stack space, it could be as simple as that.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
Dependent on how you're outputting to the UART, you might not need a mailbox; the UART driver implements a circular buffer, whose size you can configure; it's then just emptied in the background. However you'll then probably need a mutex to manage access to the output buffer - it gets fun working out which thread wrote what otherwise!
I've implemented my own printf() equivalent which blocks on the mutex and uses chprintf(); I've also allowed direct access to the mutex and other routines, so that the output of several independent print statements can be guaranteed to be together.
JSStabl
Post by JSStabl »
The Library was written by myself :) I just want to keep the generic printf instead of the chprintf in there so I can run it on a local machine or a test environment without the chibi code. That keeps the functionality of that part of the code agnostic of the system its being run on.
I was hoping to be able to implement the _write_r function and there just add strings to the serial Q, but it seems printf does some more magic than just calling _write_r. When using the STM32 HAL library implementaing _write for printf works fine.
@Steved could you share your implementation?
steved
Post by steved »
It's nothing particularly special (although I've edited out some complications peculiar to my requirements).
I've used a different name for the function, but it should be possible to override the library printf().
debugprintf.7z
(1.27 KiB) Downloaded 494 times
JSStabl
Post by JSStabl »
Thanks steve! Looks really interesting, I would keep the Mailbox logic, since I don't want to interrupt any fast threads with a blocking write. I'm thinking about using sprintf and then pushing that to the mailbox q. Only thing I need to figure out what to do when the thread isn't running yet (i.e. startup code).
Heres my macro that overrides printf:
#define printf(MESSAGE,args...) { \
  const char *A[] = {MESSAGE}; \
  BaseSequentialStream *stream = (BaseSequentialStream *)&SD3; \
  if(sizeof(A) > 0) {\
    chprintf(stream,*A,##args); \
  } else {\
    chprintf(stream,"\n"); \
Can I initialize the q at the start of my main? When I put the chMBObjectInit in my main instead of the beginning of the thread it stops working.
