I'm using the MMC over SPI driver to write data to a memory card using an STM32L4R5ZI-NUCLEO144 board. I'm using SP1 bus (8 bits) and these speeds:
// Maximum speed SPI configuration
// 3.75 MBits/s, CPHA=0, CPOL=0, MSb first.
static const SPIConfig highspeed = {
// Enables the circular buffer mode.
false,
// Operation complete callback or @p NULL.
NULL,
// The chip select port.
GPIOF,
// The chip select pad number.
14U,
// SPI CR1 register initialization data.
SPI_CR1_BR_2,
// SPI CR2 register initialization data.
SPI_CR2_DS_2 | SPI_CR2_DS_1 | SPI_CR2_DS_0
// Low speed SPI configuration
// 468.75 KBits/s, CPHA=0, CPOL=0, MSb first.
static const SPIConfig lowspeed = {
false,
NULL,
GPIOF,
14U,
SPI_CR1_BR_2 | SPI_CR1_BR_1 | SPI_CR1_BR_0,
Occasionally, the mmconnect() function does not respond. After carrying out a trace, I have noticed that the program gets stuck on the line: (void) osalThreadSuspendS(&spip->thread); of the spiReceive() function.
* @brief Receives data from the SPI bus.
* @details This synchronous function performs a receive operation.
* @pre In order to use this function the option @p SPI_USE_WAIT must be
* enabled.
* @pre In order to use this function the driver must have been configured
* without callbacks (@p end_cb = @p NULL).
* @note The buffers are organized as uint8_t arrays for data sizes below
* or equal to 8 bits else it is organized as uint16_t arrays.
* @param[in] spip pointer to the @p SPIDriver object
* @param[in] n number of words to receive
* @param[out] rxbuf the pointer to the receive buffer
* @api
void spiReceive(SPIDriver *spip, size_t n, void *rxbuf) {
osalDbgCheck((spip != NULL) && (n > 0U) && (rxbuf != NULL));
#if SPI_SUPPORTS_CIRCULAR
osalDbgCheck((spip->config->circular == false) || ((n & 1U) == 0U));
osalSysLock();
osalDbgAssert(spip->state == SPI_READY, "not ready");
spiStartReceiveI(spip, n, rxbuf);
osalSysUnlock();
I don't know why. Is it a problem with the specified speed (Prescaler 32: 3.75 MBits/s)? Why does the thread is suspended and never wake up?
