STM32F407VG SPI DMA failure
HonzaNbk
Post by HonzaNbk »
I am newbie in ChibiOS, I would like learn it. I have own board with MCU STM32F407VG, I tried write some functions for communication with AT25SF128ASHBT throught SPI.
When I tried comunicate with memory with lib from STM32Cube the memory comunicate well, when I try write similar code for Chibi, I get system halt with reason DMA failure code. How can I fix it?
My code looks like this
  SPIConfig config;
  config.circular=false;
  config.ssport=GPIOA;
  config.sspad=SPI3NSS;
  config.end_cb=NULL;
  config.cr1 =SPI_CR1_BR_0|SPI_CR1_BR_1;   // memory comunicate in SPI mode 0 or 3
  config.cr2 =0;
in while i call:
uint8_t UID[8];
   AT25SF128ASHBT_ReadUniqueID(&SPID3,&config,UID);
         chThdSleepMilliseconds(1000);
I have similar functions for works with memory.
void AT25SF128ASHBT_ReadUniqueID(SPIDriver *spip,SPIConfig *config,uint8_t *id)
    uint8_t dataTx[5];
   memset(dataTx,0,sizeof(dataTx));
   dataTx[0]=MEM_READ_UNIQUE_ID;
    spiAcquireBus(spip);
    spiStart(spip,config);
    spiSelect(spip);
    spiStartSend(spip,5,dataTx);
    spiStartReceive(spip,8,id);
    spiUnselect(spip);
    spiStop(spip);
    spiReleaseBus(spip);
Re: STM32F407VG SPI DMA failure
Note, your configuration structure needs to be "static const", it must exists while the driver is running so no auto variables.
A DMA usually can fail when you make it access non-mapped memory so check your pointers.
HonzaNbk
Post by HonzaNbk »
Giovanni wrote:Note, your configuration structure needs to be "static const", it must exists while the driver is running so no auto variables.
I am thinking that my configuration exists, when I call spi functions.
Giovanni wrote:A DMA usually can fail when you make it access non-mapped memory so check your pointers.
I change declaration UID to out of while cycle, but i had same situations.
After that i change my function to:
void AT25SF128ASHBT_ReadUniqueID(SPIDriver *spip,SPIConfig *config,uint8_t *id){
    uint8_t dataTx[13];
    uint8_t dataRx[13];
    memset(dataRx,0,sizeof(dataRx));
    spiSelect(spip);
    spiStartExchange(spip,13,dataTx,dataRx);
    spiUnselect(spip);
    spiStop(spip);
    memcpy(id,&dataRx[5],8);
SPI send and receive data only twice.
It is also interesting, the time of second exchange, because i call chThdSleepMilliseconds(1000) after this function.
You set the callback to NULL, how do you know when SPI has finished a transfer? you cannot begin another one until it is over. Perhaps you need spiExchange() not spiStartExchange().
