I upgraded a project from ChibiOS 18 to 20. I noticed that the interrupt handler for TIM9 under PWM was removed. I put back the changes and it appears to be working. Here are the three code changes. Thanks!
[nfo]diff --git a/os/hal/ports/STM32/LLD/TIMv1/hal_pwm_lld.c b/os/hal/ports/STM32/LLD/TIMv1/hal_pwm_lld.c
index eb6bebc7e..9b10df847 100644
--- a/os/hal/ports/STM32/LLD/TIMv1/hal_pwm_lld.c
+++ b/os/hal/ports/STM32/LLD/TIMv1/hal_pwm_lld.c
@@ -364,7 +364,22 @@ OSAL_IRQ_HANDLER(STM32_TIM8_CC_HANDLER) {
#if STM32_PWM_USE_TIM9 || defined(__DOXYGEN__)
#if !defined(STM32_TIM9_SUPPRESS_ISR)
-#error "TIM9 ISR not defined by platform"
+#if !defined(STM32_TIM9_HANDLER)
+#error "STM32_TIM9_HANDLER not defined"
+#endif
+ * * @brief TIM9 interrupt handler.
+ * * @isr
+OSAL_IRQ_HANDLER(STM32_TIM9_HANDLER) {
+ OSAL_IRQ_PROLOGUE();
+ pwm_lld_serve_interrupt(&PWMD9);
+ OSAL_IRQ_EPILOGUE();
#endif /* !defined(STM32_TIM9_SUPPRESS_ISR) */
#endif /* STM32_PWM_USE_TIM9 */
@@ -683,6 +698,9 @@ void pwm_lld_start(PWMDriver *pwmp) {
if (&PWMD9 == pwmp) {
rccEnableTIM9(true);
rccResetTIM9();
+#if !defined(STM32_TIM9_SUPPRESS_ISR)
+ nvicEnableVector(STM32_TIM9_NUMBER, STM32_PWM_TIM9_IRQ_PRIORITY);
+#endif
#if defined(STM32_TIM9CLK)
pwmp->clock = STM32_TIM9CLK;
#else
@@ -1059,6 +1077,9 @@ void pwm_lld_stop(PWMDriver *pwmp) {
+ nvicDisableVector(STM32_TIM9_NUMBER);
+#endif
rccDisableTIM9();
#endif[/nfo]
Bug fix for TIM9 interrupt for PWM Topic is solved
Re: Bug fix for TIM9 interrupt for PWM
The change is intentional, those IRQs sources that share the IRQ handler with other sources are no more defined into the drivers. Recent STM32s define shared handlers in stm32_irq.c so that error is not triggered. Some older STM32s have not yet been updated.
You may define the ISR in your application code making sure to define that macro (perhaps in mcuconf.h) so that the #error is not triggered.
Thank you for the response. Looking at all the other ISR handlers, I now understand the problem.
I am using the STM32F4 platform and it is only missing TIM9. I am hoping that you can accept this patch for the STM32F4 platform that adds TIM9 interrupt support back. I have tested it and it works.
I put the patched code here and also attached it. Thanks!
diff --git a/os/hal/ports/STM32/LLD/TIMv1/stm32_tim9.inc b/os/hal/ports/STM32/LLD/TIMv1/stm32_tim9.inc
new file mode 100644
index 000000000..7aebb4a64
--- /dev/null
+++ b/os/hal/ports/STM32/LLD/TIMv1/stm32_tim9.inc
@@ -0,0 +1,133 @@
+ ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
+ Licensed under the Apache License, Version 2.0 (the "License");
+ you may not use this file except in compliance with the License.
+ You may obtain a copy of the License at
+ http://www.apache.org/licenses/LICENSE-2.0
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the License is distributed on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the License for the specific language governing permissions and
+ limitations under the License.
+ * @file TIMv1/stm32_tim9.inc
+ * @brief Shared TIM9 handler.
+ * @addtogroup STM32_TIM9_HANDLER
+/* Driver local definitions. */
+/* Derived constants and error checks. */
+/* Registry checks for robustness.*/
+#if !defined(STM32_HAS_TIM9)
+#error "STM32_HAS_TIM9 not defined in registry"
+#endif
+/* Driver checks for robustness, undefined USE macros are defaulted to
+ FALSE. This makes this module independent from drivers implementation.*/
+#if !defined(STM32_GPT_USE_TIM9)
+#define STM32_GPT_USE_TIM9 FALSE
+#endif
+#if !defined(STM32_ICU_USE_TIM9)
+#define STM32_ICU_USE_TIM9 FALSE
+#endif
+#if !defined(STM32_PWM_USE_TIM9)
+#define STM32_PWM_USE_TIM9 FALSE
+#endif
+#if !defined(STM32_ST_USE_TIM9)
+#define STM32_ST_USE_TIM9 FALSE
+#endif
+#if STM32_HAS_TIM9
+/* Priority settings checks.*/
+#if !defined(STM32_IRQ_TIM9_PRIORITY)
+#error "STM32_IRQ_TIM9_PRIORITY not defined in mcuconf.h"
+#endif
+#if !OSAL_IRQ_IS_VALID_PRIORITY(STM32_IRQ_TIM9_PRIORITY)
+#error "Invalid IRQ priority assigned to STM32_IRQ_TIM9_PRIORITY"
+#endif
+#endif /* STM32_HAS_TIM9 */
+/* Driver exported variables. */
+/* Driver local variables. */
+/* Driver local functions. */
+static inline void tim9_irq_init(void) {
+#if defined(STM32_TIM9_IS_USED)
+ nvicEnableVector(STM32_TIM9_NUMBER, STM32_IRQ_TIM9_PRIORITY);
+#endif
+static inline void tim9_irq_deinit(void) {
+#endif
+/* Driver interrupt handlers. */
+#if defined(STM32_TIM9_IS_USED) || defined(__DOXYGEN__)
+ * @brief TIM9 interrupt handler.
+ * @isr
+#if HAL_USE_GPT
+#if STM32_GPT_USE_TIM9
+ gpt_lld_serve_interrupt(&GPTD9);
+#endif
+#endif
+#if HAL_USE_ICU
+#if STM32_ICU_USE_TIM9
+ icu_lld_serve_interrupt(&ICUD9);
+#endif
+#endif
+#if HAL_USE_PWM
+#if STM32_PWM_USE_TIM9
+#endif
+#endif
+#if 1
+#if STM32_ST_USE_TIM9
+ st_lld_serve_interrupt();
+#endif
+#endif
+#endif
+/* Driver exported functions. */
diff --git a/os/hal/ports/STM32/STM32F4xx/stm32_isr.c b/os/hal/ports/STM32/STM32F4xx/stm32_isr.c
index 08237e1c3..65767f908 100644
--- a/os/hal/ports/STM32/STM32F4xx/stm32_isr.c
+++ b/os/hal/ports/STM32/STM32F4xx/stm32_isr.c
@@ -51,6 +51,8 @@
+#include "stm32_tim9.inc"
#if (HAL_USE_PAL && (PAL_USE_WAIT || PAL_USE_CALLBACKS)) || defined(__DOXYGEN__)
#if !defined(STM32_DISABLE_EXTI0_HANDLER)
@@ -223,6 +225,8 @@ OSAL_IRQ_HANDLER(VectorE0) {
void irqInit(void) {
+ tim9_irq_init();
#if HAL_USE_PAL
nvicEnableVector(EXTI0_IRQn, STM32_IRQ_EXTI0_PRIORITY);
nvicEnableVector(EXTI1_IRQn, STM32_IRQ_EXTI1_PRIORITY);
@@ -241,6 +245,8 @@ void irqInit(void) {
void irqDeinit(void) {
+ tim9_irq_deinit();
#if HAL_USE_PAL
nvicDisableVector(EXTI0_IRQn);
nvicDisableVector(EXTI1_IRQn);
diff --git a/os/hal/ports/STM32/STM32F4xx/stm32_isr.h b/os/hal/ports/STM32/STM32F4xx/stm32_isr.h
index 6a826f6a3..3499794ec 100644
--- a/os/hal/ports/STM32/STM32F4xx/stm32_isr.h
+++ b/os/hal/ports/STM32/STM32F4xx/stm32_isr.h
@@ -29,6 +29,12 @@
/* Driver constants. */
+ * @name ISRs suppressed in standard drivers
+#define STM32_TIM9_SUPPRESS_ISR
* @name ISR names and numbers remapping
- patch.zip
- Patch with new include file.
- (3 KiB) Downloaded 448 times
The existing 20.3.x ChibiOS branch is intended to support TIM9 through stm32_tim1_9_10_11.inc
There is a typo in that file at line 191...
Should be...
Try removing your patch, edit os/hal/ports/STM32/LLD/TIMv1/stm32_tim1_9_10_11.inc as above and let us know how that goes.
Bob
#if defined(STM32_TIM1_IS_USED) || defined(STM32_TIM19_IS_USED) || \
Should be...
#if defined(STM32_TIM1_IS_USED) || defined(STM32_TIM9_IS_USED) || \
Bob
It worked! Thank you!
Here are the three files that need to change:
diff --git a/os/hal/ports/STM32/LLD/TIMv1/stm32_tim1_9_10_11.inc b/os/hal/ports/STM32/LLD/TIMv1/stm32_tim1_9_10_11.inc
index bebcf542e..bffbf3b70 100644
--- a/os/hal/ports/STM32/LLD/TIMv1/stm32_tim1_9_10_11.inc
+++ b/os/hal/ports/STM32/LLD/TIMv1/stm32_tim1_9_10_11.inc
@@ -188,7 +188,7 @@ static inline void tim1_tim9_tim10_tim11_irq_deinit(void) {
-#if defined(STM32_TIM1_IS_USED) || defined(STM32_TIM19_IS_USED) || \
+#if defined(STM32_TIM1_IS_USED) || defined(STM32_TIM9_IS_USED) || \
* @brief TIM1-BRK, TIM9 interrupt handler.
index 08237e1c3..232177aee 100644
@@ -51,6 +51,8 @@
+#include "stm32_tim1_9_10_11.inc"
+ tim1_tim9_tim10_tim11_irq_init();
#if HAL_USE_PAL
+ tim1_tim9_tim10_tim11_irq_deinit();
#if HAL_USE_PAL
nvicDisableVector(EXTI1_IRQn);Code: Select all
index 6a826f6a3..727a8069a 100644
@@ -29,6 +29,12 @@
@@ -105,7 +111,7 @@
#define STM32_TIM7_HANDLER Vector11C
#define STM32_TIM8_UP_HANDLER VectorF0
#define STM32_TIM8_CC_HANDLER VectorF8
-#define STM32_TIM9_HANDLER VectorA0
+#define STM32_TIM1_BRK_TIM9_HANDLER VectorA0
#define STM32_TIM10_HANDLER VectorA4 /* Note: same as STM32_TIM1_UP */
#define STM32_TIM11_HANDLER VectorA8
#define STM32_TIM12_HANDLER VectorEC
@@ -122,7 +128,7 @@
#define STM32_TIM7_NUMBER 55
#define STM32_TIM8_UP_NUMBER 44
#define STM32_TIM8_CC_NUMBER 46
-#define STM32_TIM9_NUMBER 24
+#define STM32_TIM1_BRK_TIM9_NUMBER 24
#define STM32_TIM10_NUMBER 25 /* Note: same as STM32_TIM1_UP */
#define STM32_TIM11_NUMBER 26
#define STM32_TIM12_NUMBER 43- Giovanni
Fixed as bug #1143.
The timers functionality has already been re-introduced in trunk code, I don't want to change the stable 20.3.x except for actual bugs.
Fixed as bug #1143.
