I have a strange problem. I am trying to prematurely end a dshot pulse driven by DMAR because its allowed timeslot has expired. All works well unless I actually try and cancel while the DMAR burst is in progress. If I do this the burst inexplicably just continues - so instead of stopping it goes on forever.
I am cancelling using dmaStreamDisable() - is there a safer way to achieve what I want that might actually stop the pulse?
I would post a picture of the Saleae trace, but difficult with this forum tech.
Cancelling DMAR in progress
Re: Cancelling DMAR in progress
I never used that feature, is it the DMA "going on forever" or is the timer stuck?
Check if the DMA stream is actually stopped.
Giovanni wrote:I never used that feature, is it the DMA "going on forever" or is the timer stuck?
Thanks Giovanni, well dmaStreamDisable() doesn't return until the EN bit is 0 - so seems like it must be stopped, maybe its that the timer is stuck - what's the best way to unstick it? Disable the timer?
Try disabling, worst case you can reset it using RCC macros.
Giovanni wrote:Try disabling, worst case you can reset it using RCC macros.
A friend pointed out that DMAR uses a final 0 in the DMA buffer to reset the timer, if it doesn't see this it continues for ever. Simply resetting the CCR registers in the timer fixes this.
