API question about usbPrepareQueued... in Kernel 3.xx
chibi21
Post by chibi21 »
Hi there,
I'm using the latest ChibiOS Version (20.3.3 => Kernel 6.1) on a STM32L052 and want to implement an usb hid driver. I found a sample project (ChibiOS/rawHID USB example from flabbergast). Unfortunately it was implemented for ChibiOS Kernel 3 and there exists a function called usbPrepareQueuedReceive and usbPrepareQueuedTransmit as well. These functions doesn't exist in Kernel 6 anymore. How can this be done in Kernel 6 ?
These are the In/Out functions for Endpoint 1 from the example:
static void ep1in_cb (USBDriver *usbp, usbep_t ep)
  (void)usbp;
  (void)ep;
  chSysLockFromISR ();
  // Check if there is data to send in the output queue
  if (oqGetFullI (&usb_output_queue) >= USB_HID_IN_REPORT_SIZE)
      chSysUnlockFromISR ();
      // Prepare the transmission
      usbPrepareQueuedTransmit (&USB_DRIVER, USBD1_IN_EP, &usb_output_queue, USB_HID_IN_REPORT_SIZE);
      usbStartTransmitI (&USB_DRIVER, USBD1_IN_EP);
static void ep1out_cb (USBDriver *usbp, usbep_t ep)
  (void)usbp;
  (void)ep;
  // Check if there is still some space left in the input queue
  if (iqGetEmptyI (&usb_input_queue) >= USB_HID_OUT_REPORT_SIZE)
      // Prepares the reception of new data
      usbPrepareQueuedReceive (&USB_DRIVER, USBD1_OUT_EP, &usb_input_queue, USB_HID_OUT_REPORT_SIZE);
      usbStartReceiveI (&USB_DRIVER, USBD1_OUT_EP);
Has somebody an advice for me or usb hid implemented for STM32 in Kernel 6 ?
Thank you in advance.
Re: API question about usbPrepareQueued... in Kernel 3.xx
You should look at current examples, the USB API has changed since then and there is no more queues support. A new "I/O buffers" mechanism is present and is used specifically for USB buffering, it is generally more efficient.
Note that queues are no more in the RT kernel, those are part of HAL now.
