I was successful in getting three virtual com ports to work on my target stm32f723. I had to give up speed to do that though (because of double memcpy that comes with serial usb).
Now I am trying to mix and match, where out of three, I want two to use serial usb while one uses raw usbTransmit(). I am not able to get this to work. I see some data being transferred and then the debugger loses connection with the target. I am still looking into the stack to figure out where it breaks.
In the meanwhile, I thought ill ask here if anyone has attempted such and if this can even be done or not.
Thanks,
AQ
ChibiOS: v20.3.2
Three serial com ports with CDC drivers
- sabdulqadir
- Has thanked: 13 times
- Been thanked: 4 times
Re: Three serial com ports with CDC drivers
I never did that but it should be possible, in the USB callbacks you need to call the Serial_USB handlers or your "raw" handlers depending on the endpoint being handled.
Other source of potential problems is the device descriptor, that one is not exactly easy to get right.
- sabdulqadir
Ok, got it to work, at least partially. No change in descriptors was needed so far.
Thanks for the help,
AQ
AQ
