dynamic sized queue
cpucooler
dynamic sized queue
Post by cpucooler »
is there any sort of queue in ChibiOS where each element can have a different size?
thanks in advance.
best regards
Re: dynamic sized queue
Not directly, you could use mailboxes and an heap allocator in that scenario.
You may look at how Objects Queues are implemented in OSLIB and replace the pool allocator with the heap allocator. The inherent problems with this approach are:
1) You cannot use it from ISRs, heap allocator does not allow that.
2) You may hit an heap fragmentation problem, this is inherent with dynamic allocation.
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
I also had this need many times, I use Giovanni solution : mailboxe and heap allocator.
When I need constant time allocation and very low fragmentation, I use TLSF as heap allocator :
tlsf heap allocator github
Alexandre
