After doing about 5 / 14 devices it crashes:
continuing.
Program received signal SIGTRAP, Trace/breakpoint trap.
_unhandled_exception () at chibios/os/common/startup/ARMCMx/compilers/GCC/vectors.c:46
46 void __attribute__((weak)) _unhandled_exception(void) {
(gdb) where
#0 _unhandled_exception () at chibios/os/common/startup/ARMCMx/compilers/GCC/vectors.c:46
#1 <signal handler called>
#2 0xfffffffe in ?? ()
(gdb) Any suggestions on how i can figure out where the crash happens?
