STM32F072 crashes... But wehre ?
Posted: Thu Jun 17, 2021 3:07 pm
by rew
I have a difficult problem. My program iterates across doing stuff with (currently not attached) SPI devices on different CS pins.
After doing about 5 / 14 devices it crashes:
continuing.
Program received signal SIGTRAP, Trace/breakpoint trap.
_unhandled_exception () at chibios/os/common/startup/ARMCMx/compilers/GCC/vectors.c:46
46 void __attribute__((weak)) _unhandled_exception(void) {
(gdb) where
#0 _unhandled_exception () at chibios/os/common/startup/ARMCMx/compilers/GCC/vectors.c:46
#1 <signal handler called>
#2 0xfffffffe in ?? ()
(gdb)
Any suggestions on how i can figure out where the crash happens?
Re: STM32F072 crashes... But wehre ?
Posted: Thu Jun 17, 2021 4:11 pm
On exception Cortex-M cores save a context structure on the PSP or MSP (depending if it was in process or exception context already), the PC is stored in that structure, you need to inspect memory starting at the xPSP value.
The structure is like this:
struct port_extctx {
uint32_t r0;
uint32_t r1;
uint32_t r2;
uint32_t r3;
uint32_t r12;
uint32_t lr_thd;
uint32_t pc;
uint32_t xpsr;
Posted: Thu Jun 17, 2021 4:48 pm
by rew
Thanks! Found it on the PSP stack. Aligns perfectly that LR and PC end up being in flash, and a couple of the registers match with what GDB tells me, i.e. unchanged since dumped on the stack... Investigating....
Update:
The crash happens in "gosleeptimout" called from "gosleep" called from chThdSleepMilliseconds called from my Blinky thread:
static THD_WORKING_AREA(waBlinky, 256);
static THD_FUNCTION (Blinky, arg)
int i;
(void)arg;
chRegSetThreadName("blinky");
make_output (MYLED2);
while (TRUE) {
chThdSleepMilliseconds(1000);
for (i=4;i;i--) {
clr_bit (MYLED2); // turn on led
chThdSleepMilliseconds (250);
set_bit (MYLED2); // turn led off
(This code was copied from an application where it would blink the state of the main statemachine, but here it just blinks the constant "4" (there is no main statemachine).
Posted: Sat Jun 19, 2021 6:02 pm
by electronic_eel
What compiler version exactly are you using?
It could be some version that is affected by these bugs:
http://forum.chibios.org/viewtopic.php?t=5281Does the bug also appear when you disable all optimization in the compiler (-O0)?
Have you tried running your program with Chibi-assertions and checks enabled (CH_DBG_SYSTEM_STATE_CHECK, CH_DBG_ENABLE_CHECKS, CH_DBG_ENABLE_ASSERTS, CH_DBG_ENABLE_STACK_CHECK)? With these options you get a fault whenever you use some os function the wrong way, fill up your stack or similar.
Posted: Sat Jun 19, 2021 6:03 pm
You should check for stack overflows too.
Posted: Mon Jun 21, 2021 1:34 pm
by rew
Yup stack overflow.
