How to make the list of all treads in ChibiOS 21?
alexblack
Been thanked: 33 times
Post by alexblack »
Hi.
For the debug purposes I need to make a list of all threads in the system. In previous versions I used this code:
  thread_t *ctp;
  /* Scanning registry.*/
  ctp = ch.rlist.newer;
  do {
    /* Exclude IDLE THREAD from list */
    if (ctp->hdr.pqueue.prio != IDLEPRIO)   {
      /* Fill elements with current task information */
      Info.TaskID     = (uint32_t) ctp;
      Info.sName      = ctp->name;
      Info.Prio       = ctp->hdr.pqueue.prio;
      Info.StackBase  = (uint32_t) ctp->wabase;
      Info.StackSize  = (uint32_t) 0;
    /* search next thread */
    sts = chSysGetStatusAndLockX();
    ctp = ctp->newer;
    if (ctp == (thread_t *)&ch.rlist) {
      ctp = NULL;
    chSysRestoreStatusX(sts);
  } while (ctp != NULL);
Now it does not compiling because all structures was changed.
Please help to make this.
Re: How to make the list of all treads in ChibiOS 21?
In order to scan the registry you need to use chRegFirstThread() and chRegNextThread() functions, it is not appropriate to use the pointers directly.
If you need an example then look at the "threads" shell command in /os/various/shell/shell_cmd.c
alexblack
Post by alexblack »
Thank you.
方悠然
Post by 方悠然 »
I've seen /os/various/shell/shell_cmd.c, I want to increase the unused ratio of the thread stack in the "threads" shell.
It seems that using chRegFirstThread() and chRegNextThread() does not get "wsp". I can only add the "wsp" parameter manually.
//my program:
#if CH_DBG_FILL_THREADS
float GetThdFreeStack(void *wsp, uint32_t size) {
uint32_t stack_unused = 0;
uint8_t *startp = (uint8_t *)wsp; //The start address of the thread stack
uint8_t *endp = (uint8_t *)wsp + size; //The address at the end of the thread stack
while (startp < endp)
if(*startp++ == CH_DBG_STACK_FILL_VALUE) ++stack_unused; //Unused thread stack space
return ((float)stack_unused - sizeof(thread_t))/((float)size - sizeof(thread_t)); //The ratio of unused stacks to the thread's total stack space
chThdCreateStatic(motor_test_thread_wa, sizeof(motor_test_thread_wa), NORMALPRIO-1, motor_test_thread, NULL);
float unused_thread1 = GetThdFreeStack(motor_test_thread_wa, sizeof(motor_test_thread_wa));
float unused_thread2 = GetThdFreeStack(......);
Is there any way to get the "wsp" list, or to add thread usage to the "threads" shell? Appreciate.
The "wabase" field of the thread structure is the base of the working area, that is your "wsp".
