Hello.
I'm working on FW byapss process implementation.
Below is my environment.
- Board : STM32F4 DISCOVERY
- OS : ChibiOS
- process block
[Test board] ←communication: I2CD1 port→ [stm32f4 disc] ←communication: I2CD2 port→ [sensor module]
In my case, how to set 2 I2C Ports?
I can't feel it yet. help please.
Firmware bypass using 2 i2c ports Topic is solved
Re: Firmware bypass using 2 i2c ports
I am not sure to understand your use case. Note that there is no official slave I2C support in ChibiOS, there could be modified drivers in the community directory.
It means chibiOS's I2C master, slave setting.
System configuration :
[Main Chip] ←(1)→ [STM32F4/Chibios/I2CD1]
(1) Main Chip : I2CD1 Master mode
STM32F4 : I2CD1 Slave mode
[STM32F4/Chibios/I2CD2] ←(2)→ [sensor]
(2) STM32F4: I2CD2 Master mode
sensor : I2CD2 Slave mode
Main chip transmits register address(including set value).
STM32F4 receives the address and transmits it to sensor.
STM32F4 receives(=read) sensor value from sensor's specific address and transmit the value to Main Chip.
Finally, Main chip receives(read) the value and use it.
I said 'Firmware bypass using 2 i2c ports' about above.
'(2)' is not difficulty.
'i2cMasterTransmitTimeout', 'i2cMasterReceiveTimeout' functions are implemented, already.
'(1)' is main problem to me.
In this case, how can I implement I2C Slave mode on ChibiOS?
As I explained, there is no I2C slave support in ChibiOS. You need to implement that at register level or to import code from ST low level libraries.
Thank you, Bob.
I'm trying that. But, It's still not easy.
I will keep doing
steved wrote:There's an alternative I2C slave, originally written by genosensor, and modified by me for the later I2C ports, if you search
I tried I2C master, slave test from link: viewtopic.php?t=3544
I used 2 boards
- Board-1(I2C Master)
- Board-2(I2C Slave)
Print receive data on Board-2(I2C Slave)
Push user switch in Board-1(I2C master) -> I2C master transmit one time
Board2 stop when I push user switch 5 times on Board-1(I2C master).
I couldn't find reason that Board-2(I2C Slave) stop.
could you check my code?
I2C master code :
[offtopic]#include "ch.h"
#include "chprintf.h"
static const SerialConfig serialCfgMst = {
115200,
0,
USART_CR2_STOP1_BITS,
0
BaseSequentialStream* chp_mst = (BaseSequentialStream*)&SD2;
static const I2CConfig i2ccfg_mst = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
static i2cflags_t errors = 0;
static uint8_t txbuf[2] = {0x00, 0x00};
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
(void)arg;
while (true) {
palSetPad(GPIOD, GPIOD_LED6); // Blue
chThdSleepMilliseconds(500);
palClearPad(GPIOD, GPIOD_LED6); // Blue
#define I2C_SLAVE_ADDR 0x18
#define I2C_TEST_VAL_1 0x23
#define I2C_TEST_VAL_2 0x45
* Application entry point.
int main(void) {
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7)| PAL_STM32_OSPEED_HIGHEST | PAL_STM32_OTYPE_PUSHPULL);
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7)| PAL_STM32_OSPEED_HIGHEST | PAL_STM32_OTYPE_PUSHPULL);
sdStart(&SD2, &serialCfgMst);
chprintf(chp_mst, "Master Driver Start : Serial\n");
//i2c pin set
palSetPadMode(GPIOB, GPIOB_PIN8, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
palSetPadMode(GPIOB, GPIOB_SDA, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
i2cStart(&I2CD1, &i2ccfg_mst);
chprintf(chp_mst, "Master Driver Start : I2C\n");
// master
msg_t status = MSG_OK;
txbuf[0] = I2C_TEST_VAL_1;
* Creates the example thread.
chprintf(chp_mst, "LED Thread start\n");
chprintf(chp_mst, "Master I2C transmit repeat start\n");
while (true) {
if (palReadPad(GPIOA, GPIOA_BUTTON))
i2cAcquireBus(&I2CD1);
status = i2cMasterTransmitTimeout(&I2CD1, 0x18, txbuf, 1, NULL, 0, TIME_INFINITE);
i2cReleaseBus(&I2CD1);
if (status != MSG_OK)
errors = i2cGetErrors(&I2CD1);
chprintf(chp_mst, "Master MSG is not OK(%d)\n", status);
else
chprintf(chp_mst, "Master MSG is OK(%d)\n", status);
chThdSleepMilliseconds(100);
i2cStop(&I2CD1);
}[/offtopic]
I2C slave code :
static const SerialConfig serialCfgSlv = {
115200,
0,
0
BaseSequentialStream* chp_slv = (BaseSequentialStream*)&SD2;
static const I2CConfig i2ccfg = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
uint8_t txBuff[4] = {0x00, 0x00, 0x00, 0x00};
uint8_t rxBuff[4] = {0x00, 0x00, 0x00, 0x00};
void onI2CSlaveReceive(I2CDriver *i2cp, const uint8_t *rxbuf, size_t rxbytes)
(void)i2cp;
(void)rxbuf;
(void)rxbytes;
void onI2CSlaveRequest(I2CDriver *i2cp)
i2cSlaveStartTransmission(i2cp, txBuff, 2);
i2cSlaveOnReceive(&I2CD2, onI2CSlaveReceive, rxBuff, 2);
txBuff[0]++;
txBuff[1]++;
* Receiver thread.
static THD_WORKING_AREA(thread1_wa, 256);
static THD_FUNCTION(thread1, arg) {
(void)arg;
chRegSetThreadName("Print");
chprintf(chp_slv, "Start...\n\r");
while(true) {
chThdSleepMilliseconds(10);
chprintf(chp_slv, "slave Receive %x, %x \n\r", rxBuff[0], rxBuff[1]);
* a LED.
(void)arg;
while (true) {
palSetPad(GPIOD, GPIOD_LED4); // Green
palClearPad(GPIOD, GPIOD_LED4); // Green
int main(void) {
sdStart(&SD2, &serialCfgSlv);
chprintf(chp_slv, "Slave Driver Start : Serial\n");
//i2c pin set
palSetPadMode(GPIOB, 10U, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
palSetPadMode(GPIOB, 11, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
i2cStart(&I2CD2, &i2ccfg);
chprintf(chp_slv, "Slave Driver Start : I2C");
i2cSlaveOnRequest(&I2CD2, onI2CSlaveRequest);
i2cSlaveMatchAddress(&I2CD2, 0x18);
chprintf(chp_mst, "Thread start : LED\n");
chThdCreateStatic(thread1_wa, sizeof(thread1_wa), NORMALPRIO, thread1, NULL);
chprintf(chp_mst, "Thread start : I2C Receive\n");
while (true) {
chThdSleepMilliseconds(50);
}[/offtopic]
I used 2 boards
I2C master code :
#include "ch.h"
115200,
0,
0
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
* a LED.
(void)arg;
while (true) {
int main(void) {
//i2c pin set
// master
while (true) {
else
i2cStop(&I2CD1);
I2C slave code :
#include "ch.h"
115200,
0,
0
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
(void)i2cp;
(void)rxbuf;
(void)rxbytes;
txBuff[0]++;
txBuff[1]++;
* Receiver thread.
(void)arg;
while(true) {
* a LED.
(void)arg;
while (true) {
int main(void) {
//i2c pin set
chprintf(chp_slv, "Thread start : LED\n");
chprintf(chp_slv, "Thread start : I2C Receive\n");
while (true) {
