steved wrote:There's an alternative I2C slave, originally written by genosensor, and modified by me for the later I2C ports, if you search
I tried I2C master, slave test from link:
viewtopic.php?t=3544I used 2 boards
- Board-1(I2C Master)
- Board-2(I2C Slave)
Print receive data on Board-2(I2C Slave)
Push user switch in Board-1(I2C master) -> I2C master transmit one time
Board2 stop when I push user switch 5 times on Board-1(I2C master).
I couldn't find reason that Board-2(I2C Slave) stop.
could you check my code?
I2C master code :
[offtopic]#include "ch.h"
#include "hal.h"
#include "chprintf.h"
static const SerialConfig serialCfgMst = {
115200,
0,
USART_CR2_STOP1_BITS,
0
BaseSequentialStream* chp_mst = (BaseSequentialStream*)&SD2;
static const I2CConfig i2ccfg_mst = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
static i2cflags_t errors = 0;
static uint8_t txbuf[2] = {0x00, 0x00};
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
(void)arg;
while (true) {
palSetPad(GPIOD, GPIOD_LED6); // Blue
chThdSleepMilliseconds(500);
palClearPad(GPIOD, GPIOD_LED6); // Blue
#define I2C_SLAVE_ADDR 0x18
#define I2C_TEST_VAL_1 0x23
#define I2C_TEST_VAL_2 0x45
* Application entry point.
int main(void) {
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7)| PAL_STM32_OSPEED_HIGHEST | PAL_STM32_OTYPE_PUSHPULL);
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7)| PAL_STM32_OSPEED_HIGHEST | PAL_STM32_OTYPE_PUSHPULL);
sdStart(&SD2, &serialCfgMst);
chprintf(chp_mst, "Master Driver Start : Serial\n");
//i2c pin set
palSetPadMode(GPIOB, GPIOB_PIN8, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
palSetPadMode(GPIOB, GPIOB_SDA, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
i2cStart(&I2CD1, &i2ccfg_mst);
chprintf(chp_mst, "Master Driver Start : I2C\n");
// master
msg_t status = MSG_OK;
txbuf[0] = I2C_TEST_VAL_1;
* Creates the example thread.
chprintf(chp_mst, "LED Thread start\n");
chprintf(chp_mst, "Master I2C transmit repeat start\n");
while (true) {
if (palReadPad(GPIOA, GPIOA_BUTTON))
i2cAcquireBus(&I2CD1);
status = i2cMasterTransmitTimeout(&I2CD1, 0x18, txbuf, 1, NULL, 0, TIME_INFINITE);
i2cReleaseBus(&I2CD1);
if (status != MSG_OK)
errors = i2cGetErrors(&I2CD1);
chprintf(chp_mst, "Master MSG is not OK(%d)\n", status);
else
chprintf(chp_mst, "Master MSG is OK(%d)\n", status);
chThdSleepMilliseconds(100);
i2cStop(&I2CD1);
}[/offtopic]
I2C slave code :
#include "hal.h"
static const SerialConfig serialCfgSlv = {
115200,
0,
0
BaseSequentialStream* chp_slv = (BaseSequentialStream*)&SD2;
static const I2CConfig i2ccfg = {
OPMODE_I2C,
100000,
STD_DUTY_CYCLE,
uint8_t txBuff[4] = {0x00, 0x00, 0x00, 0x00};
uint8_t rxBuff[4] = {0x00, 0x00, 0x00, 0x00};
void onI2CSlaveReceive(I2CDriver *i2cp, const uint8_t *rxbuf, size_t rxbytes)
(void)i2cp;
(void)rxbuf;
(void)rxbytes;
void onI2CSlaveRequest(I2CDriver *i2cp)
i2cSlaveStartTransmission(i2cp, txBuff, 2);
i2cSlaveOnReceive(&I2CD2, onI2CSlaveReceive, rxBuff, 2);
txBuff[0]++;
txBuff[1]++;
* Receiver thread.
static THD_WORKING_AREA(thread1_wa, 256);
static THD_FUNCTION(thread1, arg) {
(void)arg;
chRegSetThreadName("Print");
chprintf(chp_slv, "Start...\n\r");
while(true) {
chThdSleepMilliseconds(10);
chprintf(chp_slv, "slave Receive %x, %x \n\r", rxBuff[0], rxBuff[1]);
* a LED.
(void)arg;
while (true) {
palSetPad(GPIOD, GPIOD_LED4); // Green
palClearPad(GPIOD, GPIOD_LED4); // Green
int main(void) {
sdStart(&SD2, &serialCfgSlv);
chprintf(chp_slv, "Slave Driver Start : Serial\n");
//i2c pin set
palSetPadMode(GPIOB, 10U, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
palSetPadMode(GPIOB, 11, PAL_MODE_ALTERNATE(4) | PAL_STM32_OTYPE_OPENDRAIN | PAL_STM32_OSPEED_HIGHEST | PAL_STM32_PUPDR_PULLUP);
i2cStart(&I2CD2, &i2ccfg);
chprintf(chp_slv, "Slave Driver Start : I2C");
i2cSlaveOnRequest(&I2CD2, onI2CSlaveRequest);
i2cSlaveMatchAddress(&I2CD2, 0x18);
chprintf(chp_mst, "Thread start : LED\n");
chThdCreateStatic(thread1_wa, sizeof(thread1_wa), NORMALPRIO, thread1, NULL);
chprintf(chp_mst, "Thread start : I2C Receive\n");
while (true) {
chThdSleepMilliseconds(50);
}[/offtopic]
