Help regarding MFSConfig
akshaim
Has thanked: 9 times
Post by akshaim »
Hi All,
I am new to ChibiOS and was trying to configure an STM32F767ZI (dual bank) to use MFS (Managed Flash Storage). I came across this descriptor for the driver `testhal/STM32/multi/EFL-MFS/main.c` about which I am a bit confused.
const MFSConfig mfscfg1 = {
  .flashp           = (BaseFlash *)&EFLD1,
  .erased           = 0xFFFFFFFFU,
  .bank_size        = 4096U,
  .bank0_start      = 128U,
  .bank0_sectors    = 2U,
  .bank1_start      = 130U,
  .bank1_sectors    = 2U
What does .bank_size, bank0_start, .bank0_sectors, .bank1_start and .bank1_sectors mean and how do we arrive at the values ? The parent structure does not provide much information about how to arrive at the values hence the forum post.
Any help is appreciated :)
Re: Help regarding MFSConfig
MFS operates on 2 backs with equal size, 4096 in that example.
The two banks can be formed by multiple flash sectors, you need to specify the 1st sector of each bank and how many sectors you need to reach the bank size (4096).
akshaim
Post by akshaim »
Thanks for the quick reply. From what I understand , for dual bank operation with sector size 128KB, this should be okay, right ?
    .bank_size        = 131,072U, //128 Sector size x 1024
    .bank0_start      = 19U, //Sector 19
    .bank0_sectors    = 1U,
    .bank1_start      = 20U, //Sector 20
    .bank1_sectors    = 1U
On a side note , does the MFS driver check if the program code is already flashed into the sector or not ?
- Akshai
That should be fine.
Banks are initialized on the 1st call to mfsInit() and are ready to use.
akshaim
Post by akshaim »
Thanks for the help :)
Need a suggestion from you on the following issue.
Question in Summary :
Is there an internal state machine that limits the device to access bank 0 while booting from bank 1 ?
Question in detail :
I have now moved to an STM32L475VC and it has two banks ( Bank 0 : 0x0800 0000 and Bank 1 0x0808 0000 ) . I have used the following configuration to flash an MFS test application by flashing the same to bank 0 and boot from bank0
        .bank_size        = 4096U,
        .bank0_start      = 60U,
        .bank1_start      = 120U, //As per the readout from STM32Cube programmer ( 0-63 Bank 0 and 63-128 Bank1)
        .bank1_sectors    = 2U
The above configuration works fine. But however, I tried to use the same configuration and flashed the program to Bank 1 and tried to boot from Bank 1 . Then the program would hang while doing
mfsStart(&mfs1, &mfscfg1);
Can you help ?
I am a little confused by MFS "banks" and L4 banks, those are two different things.
You should try to have both "MFS banks" in the same "L4 bank" and execute the program from the other "L4 bank". If you don't do this then you will have a RWW issue (red while write), that could be the hang you are experiencing. You should not read (or execute from) a bank while you are programming/erasing it.
akshaim
Post by akshaim »
Good day to you. Thanks for the reply.
I tried your suggestion with the following configuration and flashed the program to bank 1 ( 0x08020000) but it does not seem to work. The program just hangs at mfsStart(&mfs1, &mfscfg1);
    .bank_size        = 4096U,
    .bank0_start      = 120U,
    .bank1_start      = 125U,
    .bank1_sectors    = 2U
The following is the flash bank organisation of STM32L475VC ( 256KB)
https://imgur.com/a/4xR5v1a
It hangs how? you need to understand how and where exactly it fails.
akshaim
Post by akshaim »
I have added debug statements and here are the errors.
 MFS Start Success 0 // mfsStart(&mfs1, &mfscfg1);
 MFS Erase Error -8 // mfsErase(&mfs1);
 Write Error -1 //mfsWriteRecord(...);
 Read Error -1 // // mfsReadRecord(...)
-8 would mean a MFS_ERR_FLASH_FAILURE. Driver does not seem to allow RW operation while booting from second bank.
The configuration of MFS is
    .bank_size        = 4096U,
    .bank0_start      = 124U,
    .bank1_start      = 126U,
    .bank1_sectors    = 2U
Regards,
Akshai M
I suggest you look at the "Read-while-write (RWW)" paragraph in the STM32 RM, the driver does no magic, it is subject to all limitations described there.
Anyway, those errors seem to originate in the flash driver not MFS itself. You may try to step into the driver and see exactly where it fails.
