can_lld_set_filters (stm32 CANv1) clobbers filters if called multiple times
Posted: Sat Nov 06, 2021 1:13 am
If you call canSTM32SetFilters multiple times, even without overlapping filter numbers in the passed in CANFilter struct, can_lld_set_filters clears our previously configured filters. This does not allow you to incrementally add to the configured filters. This is strange because the loop in can_lld_set_filters where it writes to the filter registers actually respects the filter number that you passed in thru CANFilter. The following is a small reordering which will 'fix' it.
static void can_lld_set_filters(CANDriver* canp,
uint32_t can2sb,
uint32_t num,
const CANFilter *cfp) {
uint32_t i;
#if STM32_CAN_USE_CAN2
if (canp == &CAND2) {
/* Set handle to CAN1, because CAN1 manages the filters of CAN2.*/
canp = &CAND1;
/* Temporarily enabling CAN clock.*/
#if STM32_CAN_USE_CAN1
if (canp == &CAND1) {
rccEnableCAN1(true);
/* Filters initialization.*/
canp->can->FMR = (canp->can->FMR & 0xFFFF0000) | CAN_FMR_FINIT;
canp->can->FMR = (canp->can->FMR & 0xFFFF0000) | (can2sb << 8) | CAN_FMR_FINIT;
#if STM32_CAN_USE_CAN3
if (canp == &CAND3) {
rccEnableCAN3(true);
if (num > 0) {
uint32_t fmask;
/* Scanning the filters array.*/
for (i = 0; i < num; i++) {
fmask = 1 << cfp->filter;
if (cfp->mode)
canp->can->FM1R |= fmask;
if (cfp->scale)
canp->can->FS1R |= fmask;
if (cfp->assignment)
canp->can->FFA1R |= fmask;
canp->can->sFilterRegister[cfp->filter].FR1 = cfp->register1;
canp->can->sFilterRegister[cfp->filter].FR2 = cfp->register2;
canp->can->FA1R |= fmask;
cfp++;
else {
/* All filters cleared.*/
canp->can->FA1R = 0;
canp->can->FM1R = 0;
canp->can->FS1R = 0;
canp->can->FFA1R = 0;
if(canp == &CAND1) {
for (i = 0; i < STM32_CAN_MAX_FILTERS; i++) {
canp->can->sFilterRegister[i].FR1 = 0;
canp->can->sFilterRegister[i].FR2 = 0;
if(canp == &CAND3) {
for (i = 0; i < STM32_CAN3_MAX_FILTERS; i++) {
/* Setting up a single default filter that enables everything for both
CANs.*/
canp->can->sFilterRegister[0].FR1 = 0;
canp->can->sFilterRegister[0].FR2 = 0;
canp->can->sFilterRegister[can2sb].FR1 = 0;
canp->can->sFilterRegister[can2sb].FR2 = 0;
canp->can->FS1R = 1;
canp->can->FA1R = 1;
canp->can->FS1R |= 1 << can2sb;
canp->can->FA1R |= 1 << can2sb;
canp->can->FMR &= ~CAN_FMR_FINIT;
/* Clock disabled, it will be enabled again in can_lld_start().*/
rccDisableCAN1();
rccDisableCAN3();
