I am playing with STM32L4R5ZI nucleo 144 board. One thing that bug me out is that with ChibiOS 21.6.x USB is not working. I am using testhal/STM32/multi/USB_CDC example.
If I use 20.3.x stable - same example is working. I can not find any difference in the two projects. New features like dynamic clock are disabled, but boost is enabled ( which must not be a problem as CR5 register value for boost is same ), also clock configuration in two projects are same. What I can say is that with 21.6.x internal PULLUP is doing nothing (maybe hardware is not functioning correct). Any Ideas what to look at ?
edit: master is not working as well
STM32L4+ USB-CDC Topic is solved
Re: STM32L4+ USB-CDC
Please use 21.11.0. Version 21.6.0 has been discontinued.
Of course please report if you have the same problem with 21.11.0.
phusho wrote:Same problem with 21.11.0
Moving in bug reports, will look at this.
Fixed as bug #1207.
You just need to change your mcuconf.h file this way:
Fixed as bug #1207.
#define STM32_PWR_CR2 (PWR_CR2_PLS_LEV0 | PWR_CR2_IOSV | PWR_CR2_USV)
Giovanni wrote:Hi,
Fixed as bug #1207.
You just need to change your mcuconf.h file this way:Code: Select all
Changes you made are working in commit I see that you have changed STM32_PLLSAI1N_VALUE to 72, It is working with previous settings also, according to configurator sheet you will have 48 MHz with 48 and STM32_PLLSAI1Q_VALUE=4. I have tested and it is working. Unless there are other complications.
Those settings are equivalent, you can use the old or the new ones depending on other constraints if needed.
