ICU Measurement 10 times too slow
THS
Post by THS »
I am trying to measure a 1kHz PWM Signal on Pin PB5 on a STM32F407 Discovery Board (I checked the 1kHz signal with a scope).
So I copied the example from HAL-STM32F407-DISCOVERY Demo folder and adapted it.
I expect to get a period of 1ms but instead I get a 10ms (see variable "too_slow_period") instead.
Which setting do I have to adjust to get correct measurement ?
Here is my code:
icucnt_t last_period, too_slow_period;
static void Thread1(void const *arg)
  (void)arg;
  while (true)
    too_slow_period = last_period;
    osDelay(1000);
 * Thread definition block.
osThreadDef(Thread1, osPriorityAboveNormal, 128, "blinker");
static void icuperiodcb(ICUDriver *icup) {
  last_period = icuGetPeriodX(icup);
static ICUConfig icucfg = {
  ICU_INPUT_ACTIVE_HIGH,
  10000,                                    /* 10kHz ICU clock frequency.   */
  NULL,
  icuperiodcb,
  NULL,
  ICU_CHANNEL_2,
  0U,
  0xFFFFFFFFU
/* Application entry point. */
int main(void) {
  osKernelInitialize();
  osThreadCreate(osThread(Thread1), NULL);
  osKernelStart();
// ---------------------ICU Measuring----------------------
icuStart(&ICUD3, &icucfg);
palSetPadMode(GPIOB, 5, PAL_MODE_ALTERNATE(2));
icuStartCapture(&ICUD3);
icuEnableNotifications(&ICUD3);
 while (true) {
    /* Doing nothing. This thread can be used for any other
       user activity.*/
    chThdSleepMilliseconds(1000);
Re: ICU Measurement 10 times too slow
Periods are measured using the timer frequency, in you case it is 10kHz, this means you get 100uS resolution, icuGetPeriod() should return 10.
THS
Post by THS »
thanks for the quick reply.
I changed the timer frequency from 10000 to 1000 and now icuGetPeriod() returns 5 instead of the expected 1
Any idea ?
If you want measure a signal around 1000Hz then you need a timer frequency much higher or you get an extreme error. Try with a 1MHz clock and it should return 1000.
If there is an error then the timer takes a wrong clock frequency for some reason, enable assertions in chconf.h and see if something is caught.
THS
Post by THS »
now it works as expected.
I think I missed that the ticks are based on the clock frequency in the ICUConfig.
Thanks a lot.
