Mutithread variable share Topic is solved
leon_titan
Has thanked: 4 times
Post by leon_titan »
bool start = false;
// thread 1
   while(true) {
      uprintf(": %u\n", start);
// main thread
void somefunc() {
   start = true;
How to share variables between threads? I use the code above but the value of "start" is changed not as expected. When I change the start to true, the print is like:
:1
:1
:1
:0
:0
:0
:0
Why and how to do that correct?
Re: Mutithread variable share
Make the variable "volatile" or the compiled will optimize it out.
leon_titan
Got it. Thx for reply.
leon_titan
after add volatile still got the same result :(
I don't see enough code for an explanation. It is possible that thread is starving the others, there are no sleep functions called inside the loop.
