PWM signal not accurate
oszfather
Post by oszfather »
I've configured the PWM driver with the following parameters using the config struct:
static PWMConfig oneshot125cfg = {
  10000,                                    /* 10kHz PWM clock frequency.   */
  20,                                         /* Prescalar ( /20 )     */
  pwmpcb,
   {PWM_OUTPUT_ACTIVE_HIGH, pwmc1cb},
   {PWM_OUTPUT_DISABLED, NULL},
  0,
  0,
  0
This give me a PWM frequency of 500Hz (2ms period). When i use a logic analyzer however I'm reading a frequency of 505Hz. The real issue though is when I'm trying to control the duty cycle. The output is only accurate for increments of 5 e.g. 10%, 15%, 20%, 25% and so on. Trying to set a duty cycle that isn't a multiple of 5 e.g. 43%, 87%, 52% etc. just rounds down to the nearest 5 multiple. E.g. setting 57% duty cycle, i measure 55% as output.
 pwmEnableChannel(&PWMD1, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD1, 9500));
Why is this and how do I get a better resolution?
edit: When raising PWM clock frequency, the accuracy drops more. 57% is now measuring as 53%. Whats happening here?
Re: PWM signal not accurate
You need to consider that the PWM driver is mapped over a real TIM unit, the values you specify need to be compatible with the current TIM settings like:
- Clock frequency.
- ARR register value (the ARR value is your 100%).
If your clock/period causes ARR to be something like "17" then you should not expect it to be able to accurately allow all your %. Select your TIM input frequency in a way that ARR is kept to an high value for your desired period, 10000 for example, that will allow for accurate percentages.
For example, if you want a PWM frequency of 1000Hz then select an input frequency like 10MHz, that will allow for high accuracy.
The driver does no magic, the STM32 manual is your best friend when selecting operating conditions.
