maple mini can bus function build fail
Moderators: tfAteba, barthess, RoccoMarco, lbednarz, utzig
skylin008
Postby skylin008 » Mon Apr 22, 2024 4:15 pm
thank you shared this impressive project.I used the maplemin(stm32f103cb) to enable the can bus function, but any error show as below:
/opt/local/lib/gcc/arm-none-eabi/13.2.0/../../../../arm-none-eabi/bin/ld: ./build/obj/hal_usb_lld.o (symbol from plugin): in function `Vector90':
(.text+0x0): multiple definition of `Vector90'; ./build/obj/hal_can_lld.o (symbol from plugin):(.text+0x0): first defined here
how to solve this issue.
the halconf.h is:
    ChibiOS - Copyright (C) 2006..2020 Giovanni Di Sirio
 * @file    templates/halconf.h
 * @brief   HAL configuration header.
 * @details HAL configuration file, this file allows to enable or disable the
 *          various device drivers from your application. You may also use
 *          this file in order to override the device drivers default settings.
 * @addtogroup HAL_CONF
#ifndef HALCONF_H
#define HALCONF_H
#define _CHIBIOS_HAL_CONF_
#define _CHIBIOS_HAL_CONF_VER_8_4_
#include "mcuconf.h"
 * @brief   Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL                         TRUE
 * @brief   Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC                         FALSE
 * @brief   Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN                         TRUE
 * @brief   Enables the cryptographic subsystem.
#if !defined(HAL_USE_CRY) || defined(__DOXYGEN__)
#define HAL_USE_CRY                         FALSE
 * @brief   Enables the DAC subsystem.
#if !defined(HAL_USE_DAC) || defined(__DOXYGEN__)
#define HAL_USE_DAC                         FALSE
 * @brief   Enables the EFlash subsystem.
#if !defined(HAL_USE_EFL) || defined(__DOXYGEN__)
#define HAL_USE_EFL                         FALSE
 * @brief   Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT                         FALSE
 * @brief   Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C                         TRUE
 * @brief   Enables the I2S subsystem.
#if !defined(HAL_USE_I2S) || defined(__DOXYGEN__)
#define HAL_USE_I2S                         FALSE
 * @brief   Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU                         FALSE
 * @brief   Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC                         FALSE
 * @brief   Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI                     FALSE
 * @brief   Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM                         FALSE
 * @brief   Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC                         FALSE
 * @brief   Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC                         FALSE
 * @brief   Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL                      TRUE
 * @brief   Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB                  TRUE
 * @brief   Enables the SIO subsystem.
#if !defined(HAL_USE_SIO) || defined(__DOXYGEN__)
#define HAL_USE_SIO                         FALSE
 * @brief   Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI                         FALSE
 * @brief   Enables the TRNG subsystem.
#if !defined(HAL_USE_TRNG) || defined(__DOXYGEN__)
#define HAL_USE_TRNG                        FALSE
 * @brief   Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART                        FALSE
 * @brief   Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB                         TRUE
 * @brief   Enables the WDG subsystem.
#if !defined(HAL_USE_WDG) || defined(__DOXYGEN__)
#define HAL_USE_WDG                         FALSE
 * @brief   Enables the WSPI subsystem.
#if !defined(HAL_USE_WSPI) || defined(__DOXYGEN__)
#define HAL_USE_WSPI                        FALSE
/* PAL driver related settings.                                              */
 * @brief   Enables synchronous APIs.
 * @note    Disabling this option saves both code and data space.
#if !defined(PAL_USE_CALLBACKS) || defined(__DOXYGEN__)
#define PAL_USE_CALLBACKS                   FALSE
#if !defined(PAL_USE_WAIT) || defined(__DOXYGEN__)
#define PAL_USE_WAIT                        FALSE
/* ADC driver related settings.                                              */
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT                        TRUE
 * @brief   Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION            TRUE
/* CAN driver related settings.                                              */
 * @brief   Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE                  FALSE
 * @brief   Enforces the driver to use direct callbacks rather than OSAL events.
#if !defined(CAN_ENFORCE_USE_CALLBACKS) || defined(__DOXYGEN__)
#define CAN_ENFORCE_USE_CALLBACKS           FALSE
/* CRY driver related settings.                                              */
 * @brief   Enables the SW fall-back of the cryptographic driver.
 * @details When enabled, this option, activates a fall-back software
 *          implementation for algorithms not supported by the underlying
 *          hardware.
 * @note    Fall-back implementations may not be present for all algorithms.
#if !defined(HAL_CRY_USE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_USE_FALLBACK                FALSE
 * @brief   Makes the driver forcibly use the fall-back implementations.
#if !defined(HAL_CRY_ENFORCE_FALLBACK) || defined(__DOXYGEN__)
#define HAL_CRY_ENFORCE_FALLBACK            FALSE
/* DAC driver related settings.                                              */
#if !defined(DAC_USE_WAIT) || defined(__DOXYGEN__)
#define DAC_USE_WAIT                        TRUE
 * @brief   Enables the @p dacAcquireBus() and @p dacReleaseBus() APIs.
#if !defined(DAC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define DAC_USE_MUTUAL_EXCLUSION            TRUE
/* I2C driver related settings.                                              */
 * @brief   Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION            TRUE
/* MAC driver related settings.                                              */
 * @brief   Enables the zero-copy API.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY                   FALSE
 * @brief   Enables an event sources for incoming packets.
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS                      TRUE
/* MMC_SPI driver related settings.                                          */
 * @brief   Timeout before assuming a failure while waiting for card idle.
 * @note    Time is in milliseconds.
#if !defined(MMC_IDLE_TIMEOUT_MS) || defined(__DOXYGEN__)
#define MMC_IDLE_TIMEOUT_MS                 1000
 * @brief   Mutual exclusion on the SPI bus.
#if !defined(MMC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define MMC_USE_MUTUAL_EXCLUSION            TRUE
/* SDC driver related settings.                                              */
 * @brief   Number of initialization attempts before rejecting the card.
 * @note    Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY                      100
 * @brief   Include support for MMC cards.
 * @note    MMC support is not yet implemented so this option must be kept
 *          at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT                     FALSE
 * @brief   Delays insertions.
 * @details If enabled this options inserts delays into the MMC waiting
 *          routines releasing some extra CPU time for the threads with
 *          lower priority, this may slow down the driver a bit however.
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING                    TRUE
 * @brief   OCR initialization constant for V20 cards.
#if !defined(SDC_INIT_OCR_V20) || defined(__DOXYGEN__)
#define SDC_INIT_OCR_V20                    0x50FF8000U
 * @brief   OCR initialization constant for non-V20 cards.
#if !defined(SDC_INIT_OCR) || defined(__DOXYGEN__)
#define SDC_INIT_OCR                        0x80100000U
/* SERIAL driver related settings.                                           */
 * @brief   Default bit rate.
 * @details Configuration parameter, this is the baud rate selected for the
 *          default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE              115200
 * @brief   Serial buffers size.
 * @details Configuration parameter, you can change the depth of the queue
 *          buffers depending on the requirements of your application.
 * @note    The default is 16 bytes for both the transmission and receive
 *          buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE                 16
/* SIO driver related settings.                                              */
#if !defined(SIO_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SIO_DEFAULT_BITRATE                 38400
 * @brief   Support for thread synchronization API.
#if !defined(SIO_USE_SYNCHRONIZATION) || defined(__DOXYGEN__)
#define SIO_USE_SYNCHRONIZATION             TRUE
/* SERIAL_USB driver related setting.                                        */
 * @brief   Serial over USB buffers size.
 * @details Configuration parameter, the buffer size must be a multiple of
 *          the USB data endpoint maximum packet size.
 * @note    The default is 256 bytes for both the transmission and receive
 *          buffers.
#if !defined(SERIAL_USB_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_SIZE             256
 * @brief   Serial over USB number of buffers.
 * @note    The default is 2 buffers.
#if !defined(SERIAL_USB_BUFFERS_NUMBER) || defined(__DOXYGEN__)
#define SERIAL_USB_BUFFERS_NUMBER           2
/* SPI driver related settings.                                              */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT                        TRUE
 * @brief   Inserts an assertion on function errors before returning.
#if !defined(SPI_USE_ASSERT_ON_ERROR) || defined(__DOXYGEN__)
#define SPI_USE_ASSERT_ON_ERROR             TRUE
 * @brief   Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION            TRUE
 * @brief   Handling method for SPI CS line.
#if !defined(SPI_SELECT_MODE) || defined(__DOXYGEN__)
#define SPI_SELECT_MODE                     SPI_SELECT_MODE_PAD
/* UART driver related settings.                                             */
#if !defined(UART_USE_WAIT) || defined(__DOXYGEN__)
#define UART_USE_WAIT                       FALSE
 * @brief   Enables the @p uartAcquireBus() and @p uartReleaseBus() APIs.
#if !defined(UART_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define UART_USE_MUTUAL_EXCLUSION           FALSE
/* USB driver related settings.                                              */
#if !defined(USB_USE_WAIT) || defined(__DOXYGEN__)
#define USB_USE_WAIT                        FALSE
/* WSPI driver related settings.                                             */
#if !defined(WSPI_USE_WAIT) || defined(__DOXYGEN__)
#define WSPI_USE_WAIT                       TRUE
 * @brief   Enables the @p wspiAcquireBus() and @p wspiReleaseBus() APIs.
#if !defined(WSPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define WSPI_USE_MUTUAL_EXCLUSION           TRUE
#endif /* HALCONF_H */
the mcuconf.h is:
#ifndef HALCONF_H
#define HALCONF_H
 *          hardware.
 *          at @p FALSE.
 *          buffers.
 *          buffers.
Has thanked: 1125 times
Been thanked: 938 times
Re: maple mini can bus function build fail
Postby Giovanni » Mon Apr 22, 2024 8:17 pm
It is a silicon limitation, from the STM32F1xx reference manual:
"In low, medium, high and XL-density devices, the USB and CAN share a dedicated 512-byte
SRAM memory for data transmission and reception, and so they cannot be used
concurrently (the shared RAM is accessed through CAN and USB exclusively). The USB
and CAN can be used in the same application but not at the same time."
They also share the same IRQ vector, this is the cause of that error.
I recommend using a more modern STM32 variant.
Return to “General Support”
Users browsing this forum: No registered users and 34 guests
