Latest ChibiOS from GitHub doesn't build if CH_CFG_USE_REGISTRY is false. See near the end of chthreads.c function chThdObjectInit, there's a line that says
(void)name;
But there's no longer a parameter called name!
Build failure if CH_CFG_USE_REGISTRY is false Topic is solved
