Hi all!
I installed Linux Mint 22 and have it up to date.
After installing ChibiStudio_Linux_2023_02.7z evrything works fiine until it comes to debugging an STM32 project.
OpenOCD on STLink (prompts for .cfg target configuration) works ok,
but executing RT-STM32F411RE-NUCLEO64 (build-ch.elf)(OpenOCD, Flash and Run) gives an error message related to the GDB.
Here is what it says:
Could not determine GDB version using command: arm-none-eabi-gdb --version
arm-none-eabi-gdb: error while loading shared libraries: libncurses.so.5: cannot open shared object file: No such file or directory
Searching the net for a solution, it seems that libnurses.so.5 is not available on Linux Mint 22 for security reasons.
Any idea on how to get this working?
Thanks ansd regards,
Wolf
Linux Mint 22 debug issues
Re: Linux Mint 22 debug issues
Open a shell then:
cd /lib/x86_64-linux-gnu
sudo ln -s ./libncursesw.so.6 ./libncursesw.so.5
sudo ln -s ./libncurses.so.6 ./libncurses.so.5
I am redoing the ChibiOS Mint VM right now and just did that.
Open a shell then:
Wow, that was fast!
I did as suggested and I got following error after:
arm-none-eabi-gdb: error while loading shared libraries: libtinfo.so.5: cannot open shared object file: No such file or directory
So i did:
sudo ln -s ./libtinfo.so.6 ./libtinfo.so.5
And debugging works!
Many thanks,
Wolf
So i did:
Many thanks,
Wolf
