STM32G051x ADC strange referance voltage
HDKLog
Post by HDKLog »
Hello, I was able to successfully setup a project for my board with STM32G051F8P6 but was unable to configure ADC properly. My voltage source is 3.3V (from LDO) but I get strange readings when I read ADC1. I have a Voltage Divider connected to ADC1 channel 1 with resistor 1 15k to the ground and 68k to Vs
And here is my ADC config:
 * ADC conversion group 2.
 * Mode:        Linear buffer, 1 channel, SW triggered.
 * Channels:    IN01.
#define ADC_GRP2_NUM_CHANNELS 1
#define ADC_GRP2_BUF_DEPTH 1
adcsample_t samples2[ADC_GRP2_BUF_DEPTH * ADC_GRP2_NUM_CHANNELS];
const ADCConversionGroup adc_grp2_cfg = {
  .circular     = false,
  .num_channels = ADC_GRP2_NUM_CHANNELS,
  .end_cb       = NULL,
  .error_cb     = adcerrorcallback,
  .cfgr1        = ADC_CFGR1_CONT | ADC_CFGR1_RES_12BIT,
  .tr1          = ADC_TR_DISABLED,
  .tr2          = ADC_TR_DISABLED,
  .tr3          = ADC_TR_DISABLED,
  .awd2cr       = 0U,
  .awd3cr       = 0U,
  .smpr         = ADC_SMPR_SMP_3P5,
  .chselr       = ADC_CHSELR_CHSEL1
I start ADC and then start sampling by executing
   * Starting PORTAB_ADC1 driver and the temperature sensor.
  adcStart(&ADCD1, NULL);
  adcConvert(&ADCD1, &adc_grp2_cfg, samples2, ADC_GRP2_BUF_DEPTH);
But when I convert read value
 float voltage = samples2 * 18.26f / 4095f;
I have 2.96V instead of 3.8V. I know This MCU has an Internal Voltage reference buffer but enabling or disabling it does not affect anything
VREFBUF->CSR = VREFBUF_CSR_ENVR | VREFBUF_CSR_VRS | VREFBUF_CSR_HIZ;
Do you have any idea what can be wrong here?
Re: STM32G051x ADC strange referance voltage
ADC_SMPR_SMP_3P5
Try increasing the sample time, there is a table somewhere in the RM or DS, it should be selected depending on the input impedance.
HDKLog
Post by HDKLog »
Thank you Giovanni, I had never thought about input impedance.
According to the datasheet:
000: 1.5 ADC clock cycles
001: 3.5 ADC clock cycles
010: 7.5 ADC clock cycles
011: 12.5 ADC clock cycles
100: 19.5 ADC clock cycles
101: 39.5 ADC clock cycles
110: 79.5 ADC clock cycles
111: 160.5 ADC clock cycles
I chose ADC_SMPR_SMP_160P5 and it works
