GPIOx sections in board.chcfg errors out for LQFP-100
Posted: Mon Apr 07, 2025 6:52 pm
For my board I wanted to implement ChibiOs. I took the "RT-STM32F407-DISCOVERY" for first build and it compiled after a while. So far so good.
Last two missing pieces so far...advice is welcome.
FIRST:
For my board with an STM32F407VGTE (100pin LQFP) there are ports ranging from "A" to "E" on the chip.
But in XML of the board "RT-STM32F407-DISCOVERY", there are pin entries up until "GPIOI" ==> I-Port which does not exist.
Further, it complains with a red mark/white cross in project explorer on board.chcfg about an error.
When I look into the "Source" tab of board.chcfg file I see in "Problems" log below following errors:
Multiple annotations found at this line:
- Child elements are missing from element 'ports'.
The following elements are expected:
- GPIOJ
Error indicated by:
{the schema}
with code: [cvc-complex-type.2.4.b]
- cvc-complex-type.2.4.b: The content of element 'ports' is not complete. One of '{GPIOJ}' is
expected.
It is missing even more GPIOx definitions even though they do not exist for this CPU. I assume it is because of the XSD on top of file:
xsi:noNamespaceSchemaLocation="http://www.chibios.org/xml/schema/boards/stm32f4xx_board.xsd">
==> Are there local XSD files available, adjusted for the chip package?
==> Why is it online? For people behind firewalls it is an unneeded problem.
SECOND:
There is also an error message with "gencfg" in the "template_path":
<configuration_settings>
<templates_path>resources/gencfg/processors/boards/stm32f4xx/templates</templates_path>
<output_path>..</output_path>
<hal_version>5.0.x</hal_version>
</configuration_settings>
Message: The word 'gencfg' is not correctly spelled
If I change two letters in the word "gencfg" to uppercase no error is shown. But, maybe this should not be uppercase, I suspect.
The "board_name" must also follow this two uppercase letters rule.
==> I cannot change the online XSD file.
What should I do?
User
FIRST:
- GPIOJ
Error indicated by:
{the schema}
expected.
SECOND:
What should I do?
User
