Using PLL for I2S on STM32F411cEu6 Black Pill
seedx
Post by seedx »
Hi and sorry if my question is too trivial.
On the said board, I am have an issue when trying to use PLL for I2S clock souce. The program got stuck waiting for PLL lock in this block of code from the os/hal/ports/STM32/STM32F4xx/hal_lld.c file:
#if STM32_ACTIVATE_PLLI2S
  /* PLLI2S activation.*/
  RCC->PLLI2SCFGR = STM32_PLLI2SR | STM32_PLLI2SN | STM32_PLLI2SP |
                    STM32_PLLI2SSRC | STM32_PLLI2SQ | STM32_PLLI2SM;
  RCC->CR |= RCC_CR_PLLI2SON;
  /* Waiting for PLL lock.*/
  while (!(RCC->CR & RCC_CR_PLLI2SRDY))
#endif /* STM32_ACTIVATE_PLLI2S */
My HAL driver settings is:
 * HAL driver system settings.
#define STM32_BKPRAM_ENABLE                 FALSE
#define STM32_HSI_ENABLED                   TRUE
#define STM32_LSI_ENABLED                   TRUE
#define STM32_CLOCK48_REQUIRED              TRUE
#define STM32_PLLM_VALUE                    25
#define STM32_PLLN_VALUE                    192
#define STM32_PLLP_VALUE                    2
#define STM32_PLLQ_VALUE                    4
#define STM32_PPRE1                         STM32_PPRE1_DIV2
#define STM32_PPRE2                         STM32_PPRE2_DIV1
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
#define STM32_RTCPRE_VALUE                  8
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSI
#define STM32_MCO1PRE                       STM32_MCO1PRE_DIV1
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYSCLK
#define STM32_MCO2PRE                       STM32_MCO2PRE_DIV5
#define STM32_I2SSRC                        STM32_I2SSRC_PLLI2S
#define STM32_PLLI2SM_VALUE                 25
#define STM32_PLLI2SN_VALUE                 192
#define STM32_PLLI2SR_VALUE                 2
Also, the HSE is defined
#if !defined(STM32_HSECLK)
#define STM32_HSECLK                25000000U
Can someone please help. Iam using ChibiOS 21.11 Thanks.
Re: Using PLL for I2S on STM32F411cEu6 Black Pill
PLLI2S uses exactly the same parameters of the other PLL, PLL activation code is also similar, this is strange. I don't have HW to test this currently.
Try looking at the CR and I2SCFGR registers just before activation and see if the values in there are as expected.
seedx
Post by seedx »
Thank you for your guidance, Giovani. I will look at the registers.
