ADCv4 incorrect ADC clock frequency Topic is solved
jschall
Post by jschall »
- ChibiOS version or subversion revision number.
master, a695d293
- Compiler.
arm-none-eabi-gcc (GNU Arm Embedded Toolchain 10-2020-q4-major) 10.2.1 20201103 (release)
- Platform and board.
STM32H753 REV V
- Nature of the problem.
STM32_ADC12_CLOCK which was computed as 3.125 MHz. Measured ADC conversion time at max SMPR (should be 810.5 ADC clock cycles) by triggering ADC12 and TIM4 using TIM3 and then reading TIM4->CNT in the interrupt. The resulting latency was MUCH lower than could be achieved by an ADC running at 3.125 MHz. Back-computing the frequency based on the interrupt latency, the MINIMUM possible ADC frequency came out as ~14 MHz.
I am still trying to understand this. These are the numbers from my setup:
STM32_PLLCLKIN          =       25000000
STM32_PLL1_DIVM_VALUE   =       25
STM32_PLL1_REF_CK       =       (STM32_PLLCLKIN / STM32_PLL1_DIVM_VALUE)
STM32_PLL1_DIVN_VALUE   =       400
STM32_PLL1_VCO_CK       =       (STM32_PLL1_REF_CK * STM32_PLL1_DIVN_VALUE)
STM32_PLL1_DIVP_VALUE   =       2
STM32_PLL1_P_CK         =       (STM32_PLL1_VCO_CK / STM32_PLL1_DIVP_VALUE)
STM32_SYS_CK            =       STM32_PLL1_P_CK
STM32_SYS_D1CPRE_CK     =       (STM32_SYS_CK / 1)
STM32_HCLK              =       (STM32_SYS_D1CPRE_CK / 4)
STM32_ADC_SCLK          =       (STM32_HCLK / 2)
STM32_ADC12_CLOCK       =       (STM32_ADC_SCLK / 4 / 2)
I have determined from a thorough reading of the reference manual that, at the very least, STM32_ADC_SCLK should be (STM32_SYS_CK / 2) instead of (STM32_HCLK / 2)
- Failure mode.
BOOST bits are set incorrectly at the very least.
Re: ADCv4 incorrect ADC clock frequency
Please post your mcuconf.h.
jschall
Post by jschall »
    ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
  this header is modelled on the one for the Nucleo-144 H743 board from ChibiOS
#pragma once
#include <adc.h>
#define STM32H7xx_MCUCONF
#define STM32H743_MCUCONF
#define STM32H753_MCUCONF
#define STM32_HSECLK 25000000U
#define STM32_LSECLK 32768U
#define STM32_LSEDRV (3U << 3U)
 * General settings.
#define STM32_SYS_CK_ENFORCED_VALUE         STM32_HSECLK
 * Memory attributes settings.
#define STM32_NOCACHE_SRAM1_SRAM2           FALSE
#define STM32_NOCACHE_SRAM3                 TRUE
 * PWR system settings.
 * Reading STM32 Reference Manual is required.
 * Register constants are taken from the ST header.
#define STM32_VOS                           STM32_VOS_SCALE1
#define STM32_PWR_CR1                       (PWR_CR1_SVOS_1 | PWR_CR1_SVOS_0)
#define STM32_PWR_CR2                       (PWR_CR2_BREN)
#define STM32_PWR_CR3                       (PWR_CR3_LDOEN | PWR_CR3_USB33DEN)
#define STM32_PWR_CPUCR                     0
 * Clock tree static settings.
#define STM32_HSI_ENABLED                   FALSE
#define STM32_LSI_ENABLED                   FALSE
#define STM32_CSI_ENABLED                   TRUE
#define STM32_HSI48_ENABLED                 TRUE
#define STM32_HSIDIV                        STM32_HSIDIV_DIV1
 * PLLs static settings.
#define STM32_PLLSRC                        STM32_PLLSRC_HSE_CK
#define STM32_PLLCFGR_MASK                  ~0
  setup PLLs based on HSE clock
#if STM32_HSECLK == 8000000U
// this gives 400MHz system clock
#define STM32_PLL1_DIVM_VALUE               1
#define STM32_PLL2_DIVM_VALUE               1
#define STM32_PLL3_DIVM_VALUE               2
#elif STM32_HSECLK == 16000000U
#define STM32_PLL1_DIVM_VALUE               2
#define STM32_PLL2_DIVM_VALUE               2
#define STM32_PLL3_DIVM_VALUE               4
#elif STM32_HSECLK == 24000000U
#define STM32_PLL1_DIVM_VALUE               3
#define STM32_PLL2_DIVM_VALUE               3
#define STM32_PLL3_DIVM_VALUE               6
#elif STM32_HSECLK == 25000000U
#define STM32_PLL1_DIVM_VALUE               25
#define STM32_PLL2_DIVM_VALUE               25
#define STM32_PLL3_DIVM_VALUE               25
#else
#error "Unsupported HSE clock"
#if (STM32_HSECLK == 8000000U) || (STM32_HSECLK == 16000000U) || (STM32_HSECLK == 24000000U)
// common clock tree for multiples of 8MHz crystals
// clock in 8mhz
#define STM32_PLL1_DIVN_VALUE               100
#define STM32_PLL1_DIVP_VALUE               2
#define STM32_PLL1_DIVQ_VALUE               8
#define STM32_PLL1_DIVR_VALUE               2
#define STM32_PLL2_DIVN_VALUE               25
#define STM32_PLL2_DIVP_VALUE               2
#define STM32_PLL2_DIVQ_VALUE               2
#define STM32_PLL2_DIVR_VALUE               2
#define STM32_PLL3_DIVN_VALUE               72
#define STM32_PLL3_DIVP_VALUE               3
#define STM32_PLL3_DIVQ_VALUE               6
#define STM32_PLL3_DIVR_VALUE               9
#define STM32_PLL1_DIVN_VALUE               400
#define STM32_PLL1_DIVQ_VALUE               4
#define STM32_PLL2_DIVN_VALUE               200
#define STM32_PLL3_DIVN_VALUE               192
#define STM32_PLL3_DIVP_VALUE               2
#define STM32_PLL3_DIVQ_VALUE               4
#define STM32_PLL3_DIVR_VALUE               6
#endif // 8MHz clock multiples
#define STM32_PLL1_ENABLED                  TRUE
#define STM32_PLL1_P_ENABLED                TRUE
#define STM32_PLL1_Q_ENABLED                TRUE
#define STM32_PLL1_R_ENABLED                TRUE
#define STM32_PLL1_FRACN_VALUE              0
#define STM32_PLL2_ENABLED                  TRUE
#define STM32_PLL2_P_ENABLED                TRUE
#define STM32_PLL2_Q_ENABLED                TRUE
#define STM32_PLL2_R_ENABLED                TRUE
#define STM32_PLL2_FRACN_VALUE              0
#define STM32_PLL3_ENABLED                  TRUE
#define STM32_PLL3_P_ENABLED                TRUE
#define STM32_PLL3_Q_ENABLED                TRUE
#define STM32_PLL3_R_ENABLED                TRUE
#define STM32_PLL3_FRACN_VALUE              0
 * Core clocks dynamic settings (can be changed at runtime).
#define STM32_SW                            STM32_SW_PLL1_P_CK
#define STM32_RTCSEL                        STM32_RTCSEL_NOCLK
#define STM32_D1CPRE                        STM32_D1CPRE_DIV1
#define STM32_D1HPRE                        STM32_D1HPRE_DIV4
#define STM32_D1PPRE3                       STM32_D1PPRE3_DIV1
#define STM32_D2PPRE1                       STM32_D2PPRE1_DIV1
#define STM32_D2PPRE2                       STM32_D2PPRE2_DIV1
#define STM32_D3PPRE4                       STM32_D3PPRE4_DIV1
 * Peripherals clocks static settings.
#define STM32_MCO1SEL                       STM32_MCO1SEL_HSE_CK
#define STM32_MCO1PRE_VALUE                 4
#define STM32_MCO2SEL                       STM32_MCO2SEL_SYS_CK
#define STM32_MCO2PRE_VALUE                 4
#define STM32_TIMPRE_ENABLE                 FALSE
#define STM32_HRTIMSEL                      0
#define STM32_STOPKERWUCK                   0
#define STM32_STOPWUCK                      0
#define STM32_RTCPRE_VALUE                  8
#define STM32_CKPERSEL                      STM32_CKPERSEL_HSE_CK
#define STM32_SDMMCSEL                      STM32_SDMMCSEL_PLL1_Q_CK
#define STM32_QSPISEL                       STM32_QSPISEL_HCLK
#define STM32_FMCSEL                        STM32_QSPISEL_HCLK
#define STM32_SWPSEL                        STM32_SWPSEL_PCLK1
#define STM32_FDCANSEL                      STM32_FDCANSEL_PLL1_Q_CK
#define STM32_DFSDM1SEL                     STM32_DFSDM1SEL_PCLK2
#define STM32_SPDIFSEL                      STM32_SPDIFSEL_PLL1_Q_CK
#define STM32_SPI45SEL                      STM32_SPI45SEL_PLL2_Q_CK
#define STM32_SPI123SEL                     STM32_SPI123SEL_PLL1_Q_CK
#define STM32_SAI23SEL                      STM32_SAI23SEL_PLL1_Q_CK
#define STM32_SAI1SEL                       STM32_SAI1SEL_PLL1_Q_CK
#define STM32_LPTIM1SEL                     STM32_LPTIM1SEL_PCLK1
#define STM32_CECSEL                        STM32_CECSEL_DISABLE
#define STM32_USBSEL                        STM32_USBSEL_PLL3_Q_CK
#define STM32_I2C123SEL                     STM32_I2C123SEL_PLL3_R_CK
#define STM32_RNGSEL                        STM32_RNGSEL_HSI48_CK
#define STM32_USART16SEL                    STM32_USART16SEL_PCLK2
#define STM32_USART234578SEL                STM32_USART234578SEL_PCLK1
#define STM32_SPI6SEL                       STM32_SPI6SEL_PLL2_Q_CK
#define STM32_SAI4BSEL                      STM32_SAI4BSEL_PLL1_Q_CK
#define STM32_SAI4ASEL                      STM32_SAI4ASEL_PLL1_Q_CK
#define STM32_ADCSEL                        STM32_ADCSEL_PLL3_R_CK
#define STM32_LPTIM345SEL                   STM32_LPTIM345SEL_PCLK4
#define STM32_LPTIM2SEL                     STM32_LPTIM2SEL_PCLK4
#define STM32_I2C4SEL                       STM32_I2C4SEL_PCLK4
#define STM32_LPUART1SEL                    STM32_LPUART1SEL_PCLK4
#define STM32_CAN_CAN1_IRQ_PRIORITY         11
#define STM32_ADC_DUAL_MODE                 TRUE
#define STM32_ADC_COMPACT_SAMPLES           FALSE
#define STM32_ADC_USE_ADC12                 FALSE
#define STM32_ADC_USE_ADC1                  FALSE
#define STM32_ADC_USE_ADC3                  FALSE
#define STM32_ADC_SAMPLES_SIZE              32
#define STM32_ADC_ADC12_DMA_STREAM          STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC3_DMA_STREAM           STM32_DMA_STREAM_ID_ANY
#define STM32_ADC_ADC12_DMA_PRIORITY        2
#define STM32_ADC_ADC3_DMA_PRIORITY         2
#define STM32_ADC_ADC12_IRQ_PRIORITY        5
#define STM32_ADC_ADC3_IRQ_PRIORITY         5
#define STM32_ADC_ADC12_CLOCK_MODE          ADC_CCR_CKMODE_AHB_DIV2
#define STM32_ADC_ADC3_CLOCK_MODE           ADC_CCR_CKMODE_AHB_DIV2
#define STM32_PWM_USE_TIM1 TRUE
#define STM32_GPT_USE_TIM3 TRUE
#define STM32_GPT_USE_TIM4 TRUE
#define STM32_SDC_USE_SDMMC1                TRUE
#define STM32_SPI_USE_SPI1                  TRUE
#define STM32_SPI_USE_SPI5                  TRUE
#define STM32_UART_USE_USART3               TRUE
#define STM32_USB_USE_OTG1                  TRUE
#define STM32_SPI_SPI1_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI1_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_RX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_SPI_SPI5_TX_DMA_STREAM        STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_RX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
#define STM32_UART_USART3_TX_DMA_STREAM     STM32_DMA_STREAM_ID_ANY
 * ST driver system settings.
#define STM32_ST_IRQ_PRIORITY               8
#define STM32_ST_USE_TIMER                  2
#define HAL_USE_GPT TRUE
#define STM32_DMA_REQUIRED
Oh, also, I'd like to clarify the ChibiOS version:
I'm using an older version of ChibiOS, but I've pulled in hal_adc_lld from master. It is possible that master does not have this issue, but as far as I can tell from the reference manual, using HCLK in the computation of ADC clock is wrong.
Your ADC clock source (STM32_ADCSEL) is set to STM32_ADCSEL_PLL3_R_CK, is it meant to be that way?
Any news?
Closing, I recommend trying more recent code.
You may try (un)defining STM32_ENFORCE_H7_REV_XY, it should force a different clock calculation and fix boost.
