Attempting to build new project
jcbless
Has thanked: 7 times
Post by jcbless »
I'm attempting to build a new project. After correcting a path, I am getting the following error:
Linking build/ch.elf
lto-wrapper: warning: Options to '-Xassembler' do not match: -alms=./build/lst/crt1.lst, -alms=./build/lst/hal.lst, dropping all '-Xassembler' and '-Wa' options.
lto1: fatal error: bytecode stream in file './build/obj/hal.o' generated with LTO version 13.0 instead of the expected 11.3
compilation terminated.
lto-wrapper: fatal error: arm-none-eabi-gcc returned 1 exit status
/home/jcbless/Projects/ChibiStudio/tools/GNU Tools ARM Embedded/11.3.1 2022q3/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld: error: lto-wrapper failed
collect2: error: ld returned 1 exit status
make: *** [../../chibios_stable-21.11.x/os/common/startup/ARMCMx/compilers/GCC/mk/rules.mk:217: build/ch.elf] Error 1
"make -j22 all" terminated with exit code 2. Build might be incomplete.
11:46:35 Build Failed. 2 errors, 0 warnings. (took 485ms)
I don't know what might cause this error regarding LTO versions. Could you please provide assistance?
jcbless
Re: Attempting to build new project
Post by jcbless »
I needed to do a make clean. After that, it built correctly.
Thanks,
John
