Here is the code:
ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
#include "ch.h"
#include "rt_test_root.h"
#include "oslib_test_root.h"
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
(void)arg;
while (true) {
palSetLine(LINE_LED1);
chThdSleepMilliseconds(50);
palSetLine(LINE_LED2);
palSetLine(LINE_LED3);
chThdSleepMilliseconds(200);
palClearLine(LINE_LED1);
palClearLine(LINE_LED2);
palClearLine(LINE_LED3);
static PWMConfig pwmcfg = {
10000,
1000,
NULL,
{PWM_OUTPUT_ACTIVE_HIGH, NULL},
0,
0,
0
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
pwmStart(&PWMD5, &pwmcfg);
//sdStart(&SD3, NULL);
* Creates the example thread.
//chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
* sleeping in a loop and check the button state.
while (1) {
pwmEnableChannel(&PWMD5, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000)); // 10% duty cycle
pwmEnableChannel(&PWMD5, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000)); // 10% duty cycle
pwmEnableChannel(&PWMD5, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000)); // 10% duty cycle
pwmEnableChannel(&PWMD5, 3, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000)); // 10% duty cycle
chThdSleepMilliseconds(500);
pwmEnableChannel(&PWMD5, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000)); // 90% duty cycle
pwmEnableChannel(&PWMD5, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000)); // 90% duty cycle
pwmEnableChannel(&PWMD5, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000)); // 90% duty cycle
pwmEnableChannel(&PWMD5, 3, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000)); // 90% duty cycle
And here is the console text:
Open On-Chip Debugger 0.11.0+dev-00433-g97db87c22 (2021-10-28-12:22)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD
srst_only separate srst_nogate srst_open_drain connect_deassert_srst
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1800 kHz
Info : STLINK V2J46S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.251968
Info : stm32h7x.cpu0: Cortex-M7 r1p1 processor detected
Info : stm32h7x.cpu0: target has 8 breakpoints, 4 watchpoints
Info : starting gdb server for stm32h7x.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
target halted due to debug-request, current mode: Thread
xPSR: 0x21000000 pc: 0x08001ea2 psp: 0x200007ec
Info : Device: STM32H74x/75x
Info : flash size probed value 2048
Info : STM32H7 flash has dual banks
Info : Bank (0) size is 1024 kb, base address is 0x08000000
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
xPSR: 0x01000000 pc: 0x080003b8 msp: 0x20000400
Info : Padding image section 0 at 0x08002b14 with 12 bytes (bank write end alignment)
Please note that this is being run on a pixhawk 6x pro with Jetson carrier board. I've had to edit board files.
Could you please assist me in finding a solution to this problem? - Thanks, John
