target halted due to debug-request
Posted: Mon Sep 22, 2025 8:38 pm
by jcbless
I am trying to Flash and Run my elf file. However when I do so, I get several "target halted due to debug-request, current mode: Thread" items listed. It is clear that the intended behavior of the code (putting out a pwm wave of 10% and 90% alternatively) is not occurring.
Here is the code:
    ChibiOS - Copyright (C) 2006..2018 Giovanni Di Sirio
#include "ch.h"
#include "hal.h"
#include "rt_test_root.h"
#include "oslib_test_root.h"
 * This is a periodic thread that does absolutely nothing except flashing
 * a LED.
  (void)arg;
  while (true) {
    palSetLine(LINE_LED1);
    chThdSleepMilliseconds(50);
    palSetLine(LINE_LED2);
    palSetLine(LINE_LED3);
    chThdSleepMilliseconds(200);
    palClearLine(LINE_LED1);
    palClearLine(LINE_LED2);
    palClearLine(LINE_LED3);
static PWMConfig pwmcfg = {
   10000,
   1000,
   NULL,
      {PWM_OUTPUT_ACTIVE_HIGH, NULL},
   0,
   0,
   0
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
  pwmStart(&PWMD5, &pwmcfg);
   * Activates the serial driver 1 using the driver default configuration.
  //sdStart(&SD3, NULL);
   * Creates the example thread.
  //chThdCreateStatic(waThread1, sizeof(waThread1), NORMALPRIO+1, Thread1, NULL);
   * sleeping in a loop and check the button state.
  while (1) {
    pwmEnableChannel(&PWMD5, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000));   // 10% duty cycle
    pwmEnableChannel(&PWMD5, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000));   // 10% duty cycle
    pwmEnableChannel(&PWMD5, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000));   // 10% duty cycle
    pwmEnableChannel(&PWMD5, 3, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 1000));   // 10% duty cycle
    chThdSleepMilliseconds(500);
    pwmEnableChannel(&PWMD5, 0, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000));   // 90% duty cycle
    pwmEnableChannel(&PWMD5, 1, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000));   // 90% duty cycle
    pwmEnableChannel(&PWMD5, 2, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000));   // 90% duty cycle
    pwmEnableChannel(&PWMD5, 3, PWM_PERCENTAGE_TO_WIDTH(&PWMD5, 9000));   // 90% duty cycle
And here is the console text:
Open On-Chip Debugger 0.11.0+dev-00433-g97db87c22 (2021-10-28-12:22)
Licensed under GNU GPL v2
For bug reports, read
Warn : Interface already configured, ignoring
Error: already specified hl_layout stlink
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : clock speed 1800 kHz
Info : STLINK V2J46S7 (API v2) VID:PID 0483:3748
Info : Target voltage: 3.251968
Info : stm32h7x.cpu0: Cortex-M7 r1p1 processor detected
Info : stm32h7x.cpu0: target has 8 breakpoints, 4 watchpoints
Info : starting gdb server for stm32h7x.cpu0 on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
xPSR: 0x21000000 pc: 0x08001ea2 psp: 0x200007ec
Info : Device: STM32H74x/75x
Info : flash size probed value 2048
Info : STM32H7 flash has dual banks
Info : Bank (0) size is 1024 kb, base address is 0x08000000
Warn : Prefer GDB command "target extended-remote :3333" instead of "target remote :3333"
xPSR: 0x01000000 pc: 0x080003b8 msp: 0x20000400
Info : Padding image section 0 at 0x08002b14 with 12 bytes (bank write end alignment)
Please note that this is being run on a pixhawk 6x pro with Jetson carrier board. I've had to edit board files.
Could you please assist me in finding a solution to this problem? - Thanks, John
Re: target halted due to debug-request
Posted: Mon Sep 22, 2025 8:55 pm
I would suggest to try the same code on some supported nucleo board, this way you can rule out some porting problem. When everything works then you can try the port.
Other suggestions: compile with -O0 for debugging and enable assertions, checks, state checker and stack checker in chconf.h.
Posted: Thu Oct 02, 2025 10:01 pm
by jcbless
I've now got the demo code with the dancing LEDs to work on a Nucleo board. It functions properly. Breakpoints function as I'd expect them to when they are placed in the section of code for turning the LEDs on and off. That board has a 753 processor on it, so I use 743 configuration to run it.
The Pixhawk 6x Pro also has a 753 on it, so I tried running the exact same project with the 743 configuration. However, the breakpoints do not function and sometimes the code appears to crash altogether because the buttons for Resume, Suspend, and Terminate all go dim. There are no LEDs that are visible from the outside, so I cannot verify the actual behavior. I haven't even double checked that the LEDs are attached to the same pins between the two boards - there's a good chance they are not. I'm just going off of the breakpoint behavior to determine that it is not working.
I also turned on the -O0 compiler option as well as the various checks you mentioned. Where do I find the outputs from the checks?
John
P.S. - Here's the OpenOCD output:
Info : Target voltage: 3.255680
Info : Bank (1) size is 1024 kb, base address is 0x08100000
xPSR: 0x61000000 pc: 0x08002416 psp: 0x200007e0
Info : Padding image section 0 at 0x080160f0 with 16 bytes (bank write end alignment)
Posted: Fri Oct 03, 2025 5:37 am
The checks cause a system halt on failure, after the halt you can break (not stop) the program and look at the stack trace, going backward you will see the assertion/check that caused the halt.
Posted: Sat Oct 04, 2025 1:10 am
by jcbless
At this point, I have explored the behavior more, and most of the time it isn't halting, but rather it is getting stuck on line 276 of hal_lld.c which is:
  while ((RCC->CR & RCC_CR_HSERDY) == 0)
This is where it is checking that HSE is stable. So it seems that the HSE clock must not be getting stable at all. This led us to think that perhaps there was a hardware problem with our board (Pixhawk 6x Pro mounted on Jetson carrier board). However, we tried reinstalling Ardupilot back on the board to check that the board would run with Ardupilot. It did run.
So we are trying to understand why ChibiOS code is failing to get beyond the check about the clock. Any ideas about why that may be occurring?
John
Posted: Sat Oct 04, 2025 4:19 am
Have you created board files for your board? there are settings related to the oscillator, is it a crystal or an external oscillator?
Posted: Sat Oct 04, 2025 7:30 pm
by jcbless
I had previously been working with modified board files, but had switched to just using the demo based board files.
Looking through the board files, I'm not seeming to see any settings relating to crystal vs other external oscillators. I may be just not understanding it. What I do see are HSEFrequency and HSEBypass.
Edit: After searching some more it appears that HSEBypass may be what is necessary to indicate an external oscillator other than a crystal oscillator. Is this correct? Today I'm not around my equipment to test.
John
Posted: Sat Oct 04, 2025 7:55 pm
You need HSE Bypass if you have an external oscillator driving the HSE input pin, if you have a crystal then the bypass must be disabled. It is covered in the STM32 RM.
Posted: Sat Oct 04, 2025 8:07 pm
by jcbless
Great, when I'm back to the office I'll test this with my equipment.
Posted: Mon Oct 06, 2025 4:55 pm
by jcbless
Switching that bit got the demo code to run.
Thanks!
