diff --git a/demos/RP/RT-RP2040-PICO/Makefile b/demos/RP/RT-RP2040-PICO/Makefile
index fa139efbd..16082acdd 100644
--- a/demos/RP/RT-RP2040-PICO/Makefile
+++ b/demos/RP/RT-RP2040-PICO/Makefile
@@ -153,7 +153,7 @@ CPPWARN = -Wall -Wextra -Wundef
# List all user C define here, like -D_DEBUG=1
-UDEFS = -DCRT0_VTOR_INIT=1 -DCRT0_EXTRA_CORES_NUMBER=1 -DPICO_NO_FPGA_CHECK -DNDEBUG
+UDEFS = -DCRT0_VTOR_INIT=1 -DCRT0_EXTRA_CORES_NUMBER=1 -DPICO_NO_FPGA_CHECK -DNDEBUG -DPICO_RP2040=1
# Define ASM defines here
UADEFS = -DCRT0_VTOR_INIT=1 -DCRT0_EXTRA_CORES_NUMBER=1
diff --git a/ext/pico-sdk 1.1.0.7z b/ext/pico-sdk 1.1.0.7z
deleted file mode 100644
index a0a6ba419..000000000
Binary files a/ext/pico-sdk 1.1.0.7z and /dev/null differ
diff --git a/os/common/ext/RP/RP2040/rp2040.h b/os/common/ext/RP/RP2040/rp2040.h
index c3919457e..c380089c1 100644
--- a/os/common/ext/RP/RP2040/rp2040.h
+++ b/os/common/ext/RP/RP2040/rp2040.h
@@ -116,7 +116,7 @@ typedef struct {
__IO uint32_t INTE0;
__IO uint32_t INTF0;
__IO uint32_t INTS0;
- __I uint32_t resvd410;
+ __IO uint32_t INTR1;
__IO uint32_t INTE1;
__IO uint32_t INTF1;
__IO uint32_t INTS1;
@@ -138,7 +138,7 @@ typedef struct {
@@ -161,7 +161,7 @@ typedef struct {
@@ -184,7 +184,7 @@ typedef struct {
diff --git a/os/hal/ports/RP/RP2040/hal_lld.c b/os/hal/ports/RP/RP2040/hal_lld.c
index d859c333c..d69f1c8fa 100644
--- a/os/hal/ports/RP/RP2040/hal_lld.c
+++ b/os/hal/ports/RP/RP2040/hal_lld.c
@@ -100,7 +100,7 @@ static void start_core1(void) {
void hal_lld_init(void) {
#if RP_NO_INIT == FALSE
- clocks_init();
+ runtime_init_clocks();
SystemCoreClock = RP_CORE_CLK;
diff --git a/os/hal/ports/RP/RP2040/hal_lld.h b/os/hal/ports/RP/RP2040/hal_lld.h
index 9c822c059..62fb5aa9f 100644
--- a/os/hal/ports/RP/RP2040/hal_lld.h
+++ b/os/hal/ports/RP/RP2040/hal_lld.h
@@ -32,6 +32,7 @@
/* From Pico-SDK */
#include "hardware/clocks.h"
+#include "pico/runtime_init.h"
/* Driver constants. */
diff --git a/os/various/pico_bindings/dumb/include/pico/config_autogen.h b/os/various/pico_bindings/dumb/include/pico/config_autogen.h
index 50d104c7f..8688c96a5 100644
--- a/os/various/pico_bindings/dumb/include/pico/config_autogen.h
+++ b/os/various/pico_bindings/dumb/include/pico/config_autogen.h
@@ -1,2 +1,28 @@
-#include "boards/pico.h"
+/* Platform selection for Pico SDK 2.x multi-platform support */
+#define PICO_RISCV 0
+#define PICO_RP2040 1
+#define PICO_RP2350 0
+#define HAS_GPIO_COPROCESSOR 0
+#define HAS_HSTX 0
+#define LIB_FREERTOS_KERNEL 0
+#define NUM_BOOT_LOCKS 0
+#ifndef LIB_PICO_MULTICORE
+#define LIB_PICO_MULTICORE 0
+#endif
+#define PICO_BOOTROM_LOCKING_ENABLED 0
+#define PICO_COMBINED_DOCS 0
+#define PICO_SECURE 0
+#define PICO_USE_GPIO_COPROCESSOR 0
+#define PICO_IE_26_29_UNCHANGED_ON_RESET 0
+#define PICO_TIME_DEFAULT_ALARM_POOL_DISABLED 0
+#define PICO_USE_STACK_GUARDS 0
+#ifndef PICO_NO_FLASH
+#define PICO_NO_FLASH 0
+#endif
+#include "boards/pico.h"
diff --git a/os/various/pico_bindings/dumb/include/pico/version.h b/os/various/pico_bindings/dumb/include/pico/version.h
index c32561577..793f76460 100644
--- a/os/various/pico_bindings/dumb/include/pico/version.h
+++ b/os/various/pico_bindings/dumb/include/pico/version.h
@@ -11,9 +11,9 @@
#ifndef _PICO_VERSION_H
#define _PICO_VERSION_H
-#define PICO_SDK_VERSION_MAJOR 1
-#define PICO_SDK_VERSION_MINOR 1
+#define PICO_SDK_VERSION_MAJOR 2
+#define PICO_SDK_VERSION_MINOR 2
#define PICO_SDK_VERSION_REVISION 0
-#define PICO_SDK_VERSION_STRING "1.1.0"
+#define PICO_SDK_VERSION_STRING "2.2.0"
diff --git a/os/various/pico_bindings/pico-sdk.mk b/os/various/pico_bindings/pico-sdk.mk
index 02ca0e4be..69a662a7a 100644
--- a/os/various/pico_bindings/pico-sdk.mk
+++ b/os/various/pico_bindings/pico-sdk.mk
@@ -1,22 +1,41 @@
# Pico-SDK files.
-PICOSDKROOT := $(CHIBIOS)/ext/pico-sdk
+PICOSDKROOT := $(CHIBIOS)/ext/pico-sdk-2.2.0
PICOSDKSRC = $(PICOSDKROOT)/src/rp2_common/hardware_clocks/clocks.c \
$(PICOSDKROOT)/src/rp2_common/hardware_pll/pll.c \
+ $(PICOSDKROOT)/src/rp2_common/hardware_ticks/ticks.c \
$(PICOSDKROOT)/src/rp2_common/hardware_watchdog/watchdog.c \
$(PICOSDKROOT)/src/rp2_common/hardware_xosc/xosc.c \
+ $(PICOSDKROOT)/src/rp2_common/pico_runtime_init/runtime_init_clocks.c \
-PICOSDKINC = $(CHIBIOS)//os/various/pico_bindings/dumb/include \
- $(PICOSDKROOT)/src/common/pico_base/include \
- $(PICOSDKROOT)/src/rp2_common/pico_platform/include \
+PICOSDKINC = $(CHIBIOS)/os/various/pico_bindings/dumb/include \
+ $(PICOSDKROOT)/src/common/pico_base_headers/include \
+ $(PICOSDKROOT)/src/common/hardware_claim/include \
+ $(PICOSDKROOT)/src/common/pico_time/include \
+ $(PICOSDKROOT)/src/rp2040/pico_platform/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_platform_compiler/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_platform_sections/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_platform_panic/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_platform_common/include \
$(PICOSDKROOT)/src/rp2_common/hardware_base/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_boot_lock/include \
$(PICOSDKROOT)/src/rp2_common/hardware_clocks/include \
$(PICOSDKROOT)/src/rp2_common/hardware_gpio/include \
$(PICOSDKROOT)/src/rp2_common/hardware_irq/include \
$(PICOSDKROOT)/src/rp2_common/hardware_pll/include \
$(PICOSDKROOT)/src/rp2_common/hardware_resets/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_sync/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_sync_spin_lock/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_ticks/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_timer/include \
$(PICOSDKROOT)/src/rp2_common/hardware_watchdog/include \
+ $(PICOSDKROOT)/src/rp2_common/hardware_vreg/include \
$(PICOSDKROOT)/src/rp2_common/hardware_xosc/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_bootrom/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_flash/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_runtime/include \
+ $(PICOSDKROOT)/src/rp2_common/pico_runtime_init/include \
+ $(PICOSDKROOT)/src/rp2_common/boot_bootrom_headers/include \
$(PICOSDKROOT)/src/rp2040/hardware_regs/include \
$(PICOSDKROOT)/src/rp2040/hardware_structs/include \
$(PICOSDKROOT)/src/boards/include
