Using ChibiOS Stable release 21.11.x
Microcontroller: STM32C071RB
I've been testing the USB driver for a while now, and have come to discover a situation where the microcontroller (STM32C071RB) freezes.
Steps:
- Simple example code, loop every 1 second print with chprintf the text "Test #<number>" to USB Driver 1 (USBD1)
- Listen to the serial communication from computer (Linux with minicom).
- When I stop listening to the serial communication, after a while, the microcontroller freezes.
- When I listen to the serial communication again, it continues like nothing happened.
Question: Is this by design or is this considered a bug?
The simple example code:
* Simple USB serial communication example.
* Listen on the USB serial port and print a message with:
* $ sudo minicom -D /dev/ttyACM0 -b 115200
* (or the appropriate device on your system).
#include "ch.h"
#include "chprintf.h"
#include "usbcfg/usbcfg.h"
int main(void) {
sduObjectInit(&PORTAB_SDU1);
sduStart(&PORTAB_SDU1, &serusbcfg);
uint32_t test_serial_usb = 0;
while (true) {
chprintf((BaseSequentialStream*)&PORTAB_SDU1, "TEST SERIAL OVER USB. Count: %U\r\n", test_serial_usb);
test_serial_usb++;
palToggleLine(LINE_LED_GREEN);
chThdSleepMilliseconds(1000);
- I also tried to check if the USB state was USB_ACTIVE, and it seems as it was. Checking for USB_ACTIVE before writing with chprintf did not seem sufficient for avoiding the freezing.
- Quick fix test 1: In the os/hal/src/hal_serial_usb.c file I replaced all TIME_INFINITE with TIME_IMMEDIATE, which made it continue to run, with the expected result of seeing the "old data" from the filled up buffer queue (obqueue) with new data being printed when I listened to serial com again.
- Quick fix test 2: I used chnWriteTimeout() and it seems to work well. Should this be considered the standard solution?
