add FSMC related code for stm32G4 Topic is solved
alex31
Has thanked: 57 times
Been thanked: 88 times
Post by alex31 »
STM32G4[78]xx devices with 100 pins or more can address external SRAM.
I have tested external SRAM support on an STM32G474-EVAL1 board before designing our own hands-on DSP PCB, and it works. Please find attached the patch adding the required ChibiOS support.
I will also submit a separate patch for contrib.
Note: this required heavy modifications to the evaluation board, because the SRAM signals are not routed to the MCU pins by default. It involved quite a bit of soldering to disconnect some of the motor-control circuitry and route the signals to the SRAM instead. Also, if anyone intends to try this on the same board, be aware that the silkscreen markings are not aligned with the 0-ohm resistors.
Alexandre
stm32g4-fmc.patch.zip
(842 Bytes) Downloaded 60 times
alex31
Re: add FSMC related code for stm32G4
Post by alex31 »
a PR has been issued : https://github.com/chibios-upstream/chibios/pull/7 to test the new way of submitting patches.
Keeping this open until it is done there.
Change merged.
