chibios 2.5.2 stm32 serial_lld.h
tdwebste
Post by tdwebste »
I am testing the demos/armcm4stm32f407-discovery with the latest chibios 2.5.2
no iar
Unfortunately the serial_lld.h file can not be found.
Re: chibios 2.5.2 stm32 serial_lld.h
The device drivers paths changed and some projects are not updated yet in the unstable release, make it use .\os\hal\platforms\STM32\USARTv1\serial_lld.c/.h.
Paths will be fixed before next release, stable release 2.4.2 is OK in this regard.
tdwebste
Post by tdwebste »
I think I have solved my own problem by updating the iar file ch.ewp
hmm, perhaps, not
The first problem is fixed, but
I have seem to bet stuck in loops waiting for chip to stabalize.
Make sure the chip is correctly flashed, it could be related to the ST-Link V2 settings (could you be running it in a simulator? of course it would not work), anyway, I will give it a try in the evening.
tdwebste
Post by tdwebste »
Thank you,
I am using 2.5.2 because I want to use the stm32f3.
I fixed the project file on the repository and the demo works correctly. Probably you are running the demo in the simulator which does not simulates peripherals this causes the endless loop.
Make sure to select "STLink v2" as debugger and to configure it correctly.
tdwebste
Post by tdwebste »
Again, thx, but that does not seem to solve the problem.
with chibois 2.5.1
Also with chibois 2.5.1 I can get it running away and the cpu gets hot, I not sure what is happening,
running multiple copies.
I can repeat this, how should I break a get gdb connected? Or can I do this throw iar? I am currently using windows iar
But reloading any chibois 2.4.2 demo or my own code works fine
running iar . 6.40.5.427
tdwebste
Post by tdwebste »
OK this is now weird
I something in my code or how my code uses chibios causes it to not allows other code to run.
After in debug mode I do a chip erase I can load other chibios code,
tdwebste
Post by tdwebste »
sorry, I don't think I know how to properly reset with stlink v2
tdwebste
Re: chibios 2.5.2 stm32 serial_lld.h ( resolved) not softwar
Post by tdwebste »
update this was not a software problem
Was solved by leaving the stm32f4discouvery board unplugged over the weekend. Worked flawlessly afterwards afterwards
