STM32F100, a PWM on Timer 17
ruslanpopov
I try to generate PWM with Timer 17 but can't to find how to do this. Demo sources and mcuconf.h uses Timer 8 maximum.
What is about TIM17?
Re: STM32F100, a PWM on Timer 17
TIM17 is not supported currently, it could be added but it only supports a single comparator so you could only use channel 0.
ruslanpopov
Do I understand right that currently it isn't possible to make PWM with TIM17?
Using the PWM driver currently not, you could enable the timer at registers level and do it anyway, not particularly hard to do.
ruslanpopov
ruslanpopov
The following code runs PWM on TIM17:
//Enable clock for the timer
RCC->APB2ENR |= RCC_APB2ENR_TIM17EN;
// Enable ARR preloading
TIM17->CR1 |= TIM_CR1_ARPE;
// Enable CCR1 preloading
TIM17->CCMR1 |= TIM_CCMR1_OC2PE;
// PWM mode 1: OC1M = 110
TIM17->CCMR1 |= (TIM_CCMR1_OC1M_2 | TIM_CCMR1_OC1M_1);
// Prescaler keeps zero to allow control PWM frequency
TIM17->PSC = 0;
// PWM Frequency 36 kHz
TIM17->ARR = 667 - 1;
// Duty cycle: 33%
TIM17->CCR1 = 222;
// Uncomment to change polarity
//TIM2->CCER |= TIM_CCER_CC2P;
// Enable Capture/Compare output 1, ie PB9
TIM17->CCER |= TIM_CCER_CC1E;
// Main Output enable
TIM17->BDTR |= TIM_BDTR_MOE;
// Start timer
TIM17->CR1 |= TIM_CR1_CEN;-
ruslanpopov
Top three graphics are captured when I have used ChibiOS' PWM on TIM4 channel 3. Looks so strange.
Bottom graphic is captured when I use register's PWM, described above.
The last one is looked as normal PWM. How to get the same with ChibiOS PWM module?
Source code: https://github.com/RaD/armka_demos/blob/97b2d331d92ae2552d04ab2f0d9c51c9718c3f62/apps/ir-tester/main.c
ruslanpopov
This night gave me an idea to check timer's registers after preparing PWM module. Results are following:
[*] TIM17/CH1 (registers way):
[*] TIM4/CH4 (PWM module way):
That's the reason of my problem!
Btw, these timers share the same pin on a chip.
How to tune PWM module to have the values of TIM17 for TIM4?
TIM17->PSC = 0
TIM17->ARR = 24001
TIM17->CCR1 = 12000[*] TIM4/CH4 (PWM module way):
TIM4->PSC = 23999
TIM4->ARR = 99
TIM4->CCR1 = 0That's the reason of my problem!
The PWM driver works as intended here. The values in the registers come from the settings in the PWM configuration structure and I find unlikely you can have the CCR1 set to zero.
If you explain what you expect to get from the PWM and post your configuration structure I could help.
ruslanpopov
Digging in sources have helped me to solve this problem.
Register way:
Its output is:
PWM Module way:
Its output is:
My "oscilloscope" shows the following in appropriate order:
I would appreciate an explanation when I should increment ARR value? I talk about this:
How to get the same result using prescaler value lower that STM32_SYSCLK?
Register way:
TIM17->PSC = 0;
// PWM Frequency
TIM17->ARR = (uint16_t) (STM32_SYSCLK / PWM_FREQ);
// Duty cycle
TIM17->CCR1 = (uint16_t) (TIM17->ARR * PWM_WIDTH);
// Start timer
chprintf((BaseSequentialStream *) &SD1, "TIM17->PSC = %d\n", TIM17->PSC);
chprintf((BaseSequentialStream *) &SD1, "TIM17->ARR = %d\n", TIM17->ARR);
chprintf((BaseSequentialStream *) &SD1, "TIM17->CCR1 = %d\n", TIM17->CCR1);Its output is:
TIM17->PSC = 0
TIM17->ARR = 24000
TIM17->CCR1 = 12000PWM Module way:
static PWMConfig pwmcfg = {
STM32_SYSCLK, /* PWM clock frequency, PSC register. */
(uint16_t) (STM32_SYSCLK / PWM_FREQ) + 1, /* Initial PWM period. ARR register*/
NULL, /* Periodic callback pointer. */
{ /* Channel configuration set dynamically below, */
{PWM_OUTPUT_DISABLED, NULL},
0 /* TIM CR2 register initialization data. */
#if STM32_PWM_USE_ADVANCED
,0 /* TIM BDTR register initialization data. */
PWMChannelConfig chcfg = { PWM_OUTPUT_ACTIVE_HIGH, NULL };
pwmcfg.channels[PWM4_CHANNEL] = chcfg;
pwmStart(&PWMD4, &pwmcfg);
pwmEnableChannel(&PWMD4, PWM4_CHANNEL,
PWM_PERCENTAGE_TO_WIDTH(&PWMD4, PWM_WIDTH * 10000));
chprintf((BaseSequentialStream *) &SD1, "TIM4->PSC = %d\n", TIM4->PSC);
chprintf((BaseSequentialStream *) &SD1, "TIM4->ARR = %d\n", TIM4->ARR);
chprintf((BaseSequentialStream *) &SD1, "TIM4->CCR4 = %d\n", TIM4->CCR4);Its output is:
TIM4->PSC = 0
TIM4->ARR = 24000
TIM4->CCR4 = 12000My "oscilloscope" shows the following in appropriate order:
(uint16_t) (STM32_SYSCLK / PWM_FREQ) + 1How to get the same result using prescaler value lower that STM32_SYSCLK?
